Hipstreet Titan Plus Screen Replacement
  1. Hipstreet Titan Plus Screen Replacement, Screen: step 1, image 1 of 2 Hipstreet Titan Plus Screen Replacement, Screen: step 1, image 2 of 2
    • Use the iFixit opening tools to pry the screen from the back casing of the device.
    • Now that the screen and back casing have been separated, lay them flat on the table with the inside facing up.
  2. Hipstreet Titan Plus Screen Replacement: step 2, image 1 of 1
    • Use the spudger tool to remove the speaker from back casing of the device.
  3. Hipstreet Titan Plus Screen Replacement: step 3, image 1 of 1
    Tool used on this step:
    Buy
    • Use the tweezers to remove the black adhesive strips covering the wires.
    • After, set the strips aside. You will use them later.
  4. Hipstreet Titan Plus Screen Replacement: step 4, image 1 of 2 Hipstreet Titan Plus Screen Replacement: step 4, image 2 of 2
    • Use the spudger to release the three black clips.
    • Ensure to remove the main far right clip, which connects the screen to the motherboard.
  5. Hipstreet Titan Plus Screen Replacement: step 5, image 1 of 2 Hipstreet Titan Plus Screen Replacement: step 5, image 2 of 2
    • Remove the three screws from the bottom of the motherboard.
  6. Hipstreet Titan Plus Screen Replacement: step 6, image 1 of 2 Hipstreet Titan Plus Screen Replacement: step 6, image 2 of 2
    • Use a spudger to gently remove the battery from the motherboard.
  7. Hipstreet Titan Plus Screen Replacement: step 7, image 1 of 1
    • All components will be removable from the screen after the battery, motherboard and all the black clips have been undone.
  8. Hipstreet Titan Plus Screen Replacement: step 8, image 1 of 2 Hipstreet Titan Plus Screen Replacement: step 8, image 2 of 2
    • Use the spudger to push back the clips along the side of the device and remove the screen.
2 other people completed this guide.
Kari Cannon
500 Reputation
4 Guides authored
UMass Dartmouth, Team 1-1, Miles Fall 2015 Member of UMass Dartmouth, Team 1-1, Miles Fall 2015
UMASSD-MILES-F15S1G1
3 Members
10 Guides authored
0 Comments
Past 24 Hours: 0
Past 7 Days: 0
Past 30 Days: 3
All Time: 544
