Hisense Chromebook C11 Screen Replacement
  1. Hisense Chromebook C11 Screen Replacement, Screen: step 1, image 1 of 1
    • Turn off the laptop and disconnect it from power.
  2. Hisense Chromebook C11 Screen Replacement: step 2, image 1 of 3 Hisense Chromebook C11 Screen Replacement: step 2, image 2 of 3 Hisense Chromebook C11 Screen Replacement: step 2, image 3 of 3
    • Snap the plastic holds off of the screen protector using the plastic opening tool.
  3. Hisense Chromebook C11 Screen Replacement: step 3, image 1 of 3 Hisense Chromebook C11 Screen Replacement: step 3, image 2 of 3 Hisense Chromebook C11 Screen Replacement: step 3, image 3 of 3
    • Remove the screw caps.
  4. Hisense Chromebook C11 Screen Replacement: step 4, image 1 of 3 Hisense Chromebook C11 Screen Replacement: step 4, image 2 of 3 Hisense Chromebook C11 Screen Replacement: step 4, image 3 of 3
    • Unscrew the screws with the Phillips #00 screwdriver and set them aside.
  5. Hisense Chromebook C11 Screen Replacement: step 5, image 1 of 3 Hisense Chromebook C11 Screen Replacement: step 5, image 2 of 3 Hisense Chromebook C11 Screen Replacement: step 5, image 3 of 3
    • Remove the screen protector.
  6. Hisense Chromebook C11 Screen Replacement: step 6, image 1 of 2 Hisense Chromebook C11 Screen Replacement: step 6, image 2 of 2
    • Unscrew the screen screws with the Phillips #000 screwdriver and set them aside. Be sure to support the screen protector in case it falls.
  7. Hisense Chromebook C11 Screen Replacement: step 7, image 1 of 2 Hisense Chromebook C11 Screen Replacement: step 7, image 2 of 2
    • Gently lay the screen down.
  8. Hisense Chromebook C11 Screen Replacement: step 8, image 1 of 3 Hisense Chromebook C11 Screen Replacement: step 8, image 2 of 3 Hisense Chromebook C11 Screen Replacement: step 8, image 3 of 3
    • Disconnect the screen.
3 other people completed this guide.
Chelsea Charles
422 Reputation
2 Guides authored
USF Tampa, Team S1-G3, Leahy Fall 2018 Member of USF Tampa, Team S1-G3, Leahy Fall 2018
USFT-LEAHY-F18S1G3
3 Members
10 Guides authored
0 Comments
Past 24 Hours: 1
Past 7 Days: 1
Past 30 Days: 2
All Time: 923
