Hisense Chromebook C11 Trackpad Replacement
  1. Hisense Chromebook C11 Trackpad Replacement, Back Panel: step 1, image 1 of 1
    • Remove the front two hub caps.
    • When finished, you should be able to remove the back cover.
  2. Hisense Chromebook C11 Trackpad Replacement: step 2, image 1 of 1
    • Unscrew the screws with the Phillips #00 screwdriver.
  3. Hisense Chromebook C11 Trackpad Replacement: step 3, image 1 of 1
    • Pry the perimeter of the case open with the plastic opening tool.
    • Remove the back panel.
  4. Hisense Chromebook C11 Trackpad Replacement, Trackpad: step 4, image 1 of 1
    • Remove the electrical tape.
  5. Hisense Chromebook C11 Trackpad Replacement: step 5, image 1 of 3 Hisense Chromebook C11 Trackpad Replacement: step 5, image 2 of 3 Hisense Chromebook C11 Trackpad Replacement: step 5, image 3 of 3
    • Flip up the bracket holding the ribbon in place.
    • Gently but firmly pull the ribbon free.
  6. Hisense Chromebook C11 Trackpad Replacement: step 6, image 1 of 1
    • Using the Phillips Head Screwdriver, remove the screws at the topmost part of the panel holding the trackpad in place.
  7. Hisense Chromebook C11 Trackpad Replacement: step 7, image 1 of 1
    Tool used on this step:
    Buy
    • Using tweezers, remove the silver electrical tape.
  8. Hisense Chromebook C11 Trackpad Replacement: step 8, image 1 of 1
    • Carefully remove the trackpad from the computer.
Cole Welham
121 Reputation
1 Guide authored
USF Tampa, Team S1-G3, Leahy Fall 2018 Member of USF Tampa, Team S1-G3, Leahy Fall 2018
USFT-LEAHY-F18S1G3
3 Members
10 Guides authored
0 Comments
Past 24 Hours: 0
Past 7 Days: 0
Past 30 Days: 3
All Time: 304
