Hisense Sero 7 Pro GPS Antenna Replacement
  1. Hisense Sero 7 Pro  GPS Antenna Replacement, GPS Antenna: step 1, image 1 of 2 Hisense Sero 7 Pro  GPS Antenna Replacement, GPS Antenna: step 1, image 2 of 2
    • Turn tablet off before disassembling it.
    • Use caution when handling device if screen is cracked.
    • Using a plastic opening tool, pry open the back cover from the tablet.
    • An extra set of hands may be required.
  2. Hisense Sero 7 Pro  GPS Antenna Replacement: step 2, image 1 of 2 Hisense Sero 7 Pro  GPS Antenna Replacement: step 2, image 2 of 2
    • Pull the Wi-Fi antenna directly upwards to remove it from the motherboard.
    • Be gentle when disconnecting the antenna because it may damage the part it is attached to.
  3. Hisense Sero 7 Pro  GPS Antenna Replacement: step 3, image 1 of 2 Hisense Sero 7 Pro  GPS Antenna Replacement: step 3, image 2 of 2
    • Insert a metal or nylon spudger on the edge of the GPS satellite and begin separating it from the adhesive.
    • Slowly peel the GPS from left to right as the GPS is clammy.
Baochau Nguyen
314 Reputation
3 Guides authored
Texas Tech, Team 38-2, Bennett Fall 2016 Member of Texas Tech, Team 38-2, Bennett Fall 2016
TTU-BENNETT-F16S38G2
4 Members
6 Guides authored
0 Comments
Past 24 Hours: 1
Past 7 Days: 1
Past 30 Days: 8
All Time: 296
