Hisense Sero 7 Pro Rear Camera Replacement
  1. Hisense Sero 7 Pro Rear Camera Replacement, Rear Camera: step 1, image 1 of 2 Hisense Sero 7 Pro Rear Camera Replacement, Rear Camera: step 1, image 2 of 2
    • Turn tablet off before dissembling it.
    • Use caution when handling device if screen is cracked.
    • Using a plastic opening tool, pry open the back cover from the tablet.
    • An extra set of hands may be required.
  2. Hisense Sero 7 Pro Rear Camera Replacement: step 2, image 1 of 1
    • Using a metal or nylon spudger, begin to peel the tape from the motherboard that it is attached to the camera.
    • If needed, the same steps can be applied to front camera.
  3. Hisense Sero 7 Pro Rear Camera Replacement: step 3, image 1 of 3 Hisense Sero 7 Pro Rear Camera Replacement: step 3, image 2 of 3 Hisense Sero 7 Pro Rear Camera Replacement: step 3, image 3 of 3
    • Pull the camera toward you to detach from the tablet.
    • Use caution when detaching camera from port.
Baochau Nguyen
314 Reputation
3 Guides authored
Texas Tech, Team 38-2, Bennett Fall 2016 Member of Texas Tech, Team 38-2, Bennett Fall 2016
TTU-BENNETT-F16S38G2
4 Members
6 Guides authored
0 Comments
Past 24 Hours: 0
Past 7 Days: 1
Past 30 Days: 2
All Time: 233
