Hisense Sero 8 Charging Port Replacement
Keanu
Keanu and 5 other contributors
Last updated on May 7, 2024
No estimate
Moderate
Missing Steps
Introduction
Go to step 1
After extended use, the charging port may be worn down. If the device will not power on after charging, the charging port may be defective.
Tools
Show more…
  1. Hisense Sero 8 Charging Port Replacement, Charging Port: step 1, image 1 of 3 Hisense Sero 8 Charging Port Replacement, Charging Port: step 1, image 2 of 3 Hisense Sero 8 Charging Port Replacement, Charging Port: step 1, image 3 of 3
    • Remove the back cover of the device using a combination of both plastic opening tools.
    • Use your plastic opening tool pry open a corner of the device, then continue down the side of the device with the tool to completely open the device.
  2. Hisense Sero 8 Charging Port Replacement: step 2, image 1 of 1
    • Remove seven of the 4.43mm screws using the Philips #00 screwdriver.
    • It is not necessary to remove the bottom two 4.43mm screws that keep the speakers in place.
  3. Hisense Sero 8 Charging Port Replacement: step 3, image 1 of 2 Hisense Sero 8 Charging Port Replacement: step 3, image 2 of 2
    Tool used on this step:
    • Gently lift the motherboard up to extract the charging port out with the tweezers.
    • Be cautious not to disconnect any wires or ribbon cables.
2 other people completed this guide.
Keanu
367 Reputation
2 Guides authored
USF Tampa, Team 1-2, Leahy Winter 2015 Member of USF Tampa, Team 1-2, Leahy Winter 2015
USFT-LEAHY-W15S1G2
3 Members
10 Guides authored
0 Comments
Past 24 Hours: 2
Past 7 Days: 9
Past 30 Days: 10
All Time: 3,839
