Hisense Sero 8 Motherboard Replacement
  1. Hisense Sero 8 Motherboard Replacement, Motherboard: step 1, image 1 of 3 Hisense Sero 8 Motherboard Replacement, Motherboard: step 1, image 2 of 3 Hisense Sero 8 Motherboard Replacement, Motherboard: step 1, image 3 of 3
    • Remove the back cover of the device using the plastic opening tool.
    • Pry open a corner of the device, then continue down the side with the tool to open the device.
  2. Hisense Sero 8 Motherboard Replacement: step 2, image 1 of 2 Hisense Sero 8 Motherboard Replacement: step 2, image 2 of 2
    • Remove the black tape located to the left of the device.
    • Remove the clear tape directly below the camera.
  3. Hisense Sero 8 Motherboard Replacement: step 3, image 1 of 1
    • Remove the seven 4.43mm screws located at the top of the device using the Phillips #00 screwdriver.
    • There is no need to remove the bottom two screws holding the speakers in place.
  4. Hisense Sero 8 Motherboard Replacement: step 4, image 1 of 1
    • Unlock the three ribbon cable connector latches to remove the cables.
  5. Hisense Sero 8 Motherboard Replacement: step 5, image 1 of 3 Hisense Sero 8 Motherboard Replacement: step 5, image 2 of 3 Hisense Sero 8 Motherboard Replacement: step 5, image 3 of 3
    • Be cautious of the extremely hot tip of the soldering iron.
    • Desolder the red, black, and yellow wires to remove the motherboard. Take a look at this guide to learn how to solder and desolder connections.
    • Desolder the black wire located on the top left of the device.
    • Once desoldered, carefully lift the motherboard out of the device.
Katharina
506 Reputation
2 Guides authored
USF Tampa, Team 1-2, Leahy Winter 2015 Member of USF Tampa, Team 1-2, Leahy Winter 2015
USFT-LEAHY-W15S1G2
3 Members
10 Guides authored
0 Comments
Past 24 Hours: 2
Past 7 Days: 2
Past 30 Days: 14
All Time: 1,355
