Hitachi CP-X2010N Lens Replacement
  1. Hitachi CP-X2010N Lens Replacement, Top Panel: step 1, image 1 of 3 Hitachi CP-X2010N Lens Replacement, Top Panel: step 1, image 2 of 3 Hitachi CP-X2010N Lens Replacement, Top Panel: step 1, image 3 of 3
    • Flip the projector upside down to expose the screws on the underside.
  2. Hitachi CP-X2010N Lens Replacement: step 2, image 1 of 3 Hitachi CP-X2010N Lens Replacement: step 2, image 2 of 3 Hitachi CP-X2010N Lens Replacement: step 2, image 3 of 3
    • Use a Phillips #2 screwdriver to remove eight black 14 mm screws holding the top panel to the main projector body.
  3. Hitachi CP-X2010N Lens Replacement: step 3, image 1 of 1
    • Flip projector right side up and orient it so you are facing the rear panel.
  4. Hitachi CP-X2010N Lens Replacement: step 4, image 1 of 3 Hitachi CP-X2010N Lens Replacement: step 4, image 2 of 3 Hitachi CP-X2010N Lens Replacement: step 4, image 3 of 3
    • Use a Phillips #2 screwdriver to remove two silver 22 mm long screws.
    • Use a Phillips #2 screwdriver to remove the short silver 10 mm screw.
  5. Hitachi CP-X2010N Lens Replacement: step 5, image 1 of 3 Hitachi CP-X2010N Lens Replacement: step 5, image 2 of 3 Hitachi CP-X2010N Lens Replacement: step 5, image 3 of 3
    • Carefully lift the top panel from the body of the projector, making sure it doesn't catch on anything.
    • Remove the panel from the body of the projector.
  6. Hitachi CP-X2010N Lens Replacement, Motherboard: step 6, image 1 of 3 Hitachi CP-X2010N Lens Replacement, Motherboard: step 6, image 2 of 3 Hitachi CP-X2010N Lens Replacement, Motherboard: step 6, image 3 of 3
    • Carefully pinch the edges of the two blue connectors and pull upwards to remove them from the motherboard.
    • Carefully pinch and remove the small gray connector next to the blue wire opposite the speakers.
  7. Hitachi CP-X2010N Lens Replacement: step 7, image 1 of 3 Hitachi CP-X2010N Lens Replacement: step 7, image 2 of 3 Hitachi CP-X2010N Lens Replacement: step 7, image 3 of 3
    • Use a Phillips #2 screwdriver to remove the two black 14 mm screws securing the button array.
    • Move the wires for better access to the screws if needed.
  8. Hitachi CP-X2010N Lens Replacement: step 8, image 1 of 3 Hitachi CP-X2010N Lens Replacement: step 8, image 2 of 3 Hitachi CP-X2010N Lens Replacement: step 8, image 3 of 3
    • Remove the bracket that was being held by the screw.
    • Take a picture or memorize its orientation for easier reinstallation.
  9. Hitachi CP-X2010N Lens Replacement: step 9, image 1 of 2 Hitachi CP-X2010N Lens Replacement: step 9, image 2 of 2
    • Pull the button array and network adapter out carefully.
    • Make sure all the wires connected to the array are unplugged.
  10. Hitachi CP-X2010N Lens Replacement: step 10, image 1 of 2 Hitachi CP-X2010N Lens Replacement: step 10, image 2 of 2
    • Use a Phillips #2 screwdriver to remove the silver 10 mm screw securing the ground wire.
    • Keep the screw and washer in an easily accessible place.
  11. Hitachi CP-X2010N Lens Replacement: step 11, image 1 of 1
    • Use a Phillips #2 screwdriver to remove the black 14 mm screw securing the motherboard to the case.
  12. Hitachi CP-X2010N Lens Replacement: step 12, image 1 of 3 Hitachi CP-X2010N Lens Replacement: step 12, image 2 of 3 Hitachi CP-X2010N Lens Replacement: step 12, image 3 of 3
    • Delicately pinch and pull off all the wired connections surrounding the outside of the motherboard.
  13. Hitachi CP-X2010N Lens Replacement: step 13, image 1 of 3 Hitachi CP-X2010N Lens Replacement: step 13, image 2 of 3 Hitachi CP-X2010N Lens Replacement: step 13, image 3 of 3
    • Use the tip of a spudger or your fingernail to flip up the small locking flap on the three orange cable locks. Then, you can safely pull the cables out.
    • Too much force could break the ribbon cable.
  14. Hitachi CP-X2010N Lens Replacement: step 14, image 1 of 2 Hitachi CP-X2010N Lens Replacement: step 14, image 2 of 2
    • Lift the motherboard out from the projector carefully so that it doesn't catch on any other components.
  15. Hitachi CP-X2010N Lens Replacement, Lens: step 15, image 1 of 3 Hitachi CP-X2010N Lens Replacement, Lens: step 15, image 2 of 3 Hitachi CP-X2010N Lens Replacement, Lens: step 15, image 3 of 3
    • Use a Phillips #2 screwdriver to remove the three black 14 mm screws holding down the projector housing.
  16. Hitachi CP-X2010N Lens Replacement: step 16, image 1 of 2 Hitachi CP-X2010N Lens Replacement: step 16, image 2 of 2
    • Loosen the three silver Phillips #2 screws that secure the lamp housing.
    • The screws are captive and do not need to be removed from the lamp housing.
  17. Hitachi CP-X2010N Lens Replacement: step 17, image 1 of 2 Hitachi CP-X2010N Lens Replacement: step 17, image 2 of 2
    • Work the projector housing loose from the two pins on the lamp housing.
  18. Hitachi CP-X2010N Lens Replacement: step 18, image 1 of 3 Hitachi CP-X2010N Lens Replacement: step 18, image 2 of 3 Hitachi CP-X2010N Lens Replacement: step 18, image 3 of 3
    • Lift the projector housing up from the left side and remove it from the case.
  19. Hitachi CP-X2010N Lens Replacement: step 19, image 1 of 3 Hitachi CP-X2010N Lens Replacement: step 19, image 2 of 3 Hitachi CP-X2010N Lens Replacement: step 19, image 3 of 3
    • Turn the front lens element counterclockwise and lift it off the projector housing.
    • The front element will have lubricant on the inside shaft. Take care not to rub any of it off.
  20. Hitachi CP-X2010N Lens Replacement: step 20, image 1 of 3 Hitachi CP-X2010N Lens Replacement: step 20, image 2 of 3 Hitachi CP-X2010N Lens Replacement: step 20, image 3 of 3
    • Inspect all glass elements for debris or damage.
    • Clean or replace the lens as needed.
4 other people completed this guide.
Chance Kidd
1,184 Reputation
6 Guides authored
0 Guide Comments
Past 24 Hours: 0
Past 7 Days: 0
Past 30 Days: 9
All Time: 317
