Hitachi HB-B102 Automatic Home Bakery II Control Panel Replacement
  1. Hitachi HB-B102 Automatic Home Bakery  II Control Panel Replacement, Control Panel: step 1, image 1 of 1
    • Begin by using a # 2 Phillips head screwdriver to remove the two 1.3 cm screws that secure the control panel onto the main body.
  2. Hitachi HB-B102 Automatic Home Bakery  II Control Panel Replacement: step 2, image 1 of 1
    • Now gently pry on the top of the control panel with a metal spudger, it should then pop up.
    • Be careful when it is being removed that you do not damage the tabs that hold the bottom of the panel in place.
  3. Hitachi HB-B102 Automatic Home Bakery  II Control Panel Replacement: step 3, image 1 of 1
    • Now flip the control panel over so that the wire connections are visible.
    • All of the wires are easily removed by grabbing the metal connector and pulling straight out from the panel.
Mike
397 Reputation
3 Guides authored
Cal Poly, Team 9-2, Banghart Winter 2017 Member of Cal Poly, Team 9-2, Banghart Winter 2017
CPSU-BANGHART-W17S9G2
3 Members
7 Guides authored
1 Guide Comment
Where can i buy the power board for hitachi home
bakery HD II -B102 and how much is the price?
janettecrown_66 - Reply
Past 24 Hours: 2
Past 7 Days: 5
Past 30 Days: 15
All Time: 573
