Holmes HEH8031 Control Buttons Replacement
  1. Holmes HEH8031 Control Buttons Replacement, Housing: step 1, image 1 of 1
    • Ensure the device is unplugged from the wall outlet.
  2. Holmes HEH8031 Control Buttons Replacement: step 2, image 1 of 1
    • Remove eight 12-mm Phillips #2 screws from the back cover.
  3. Holmes HEH8031 Control Buttons Replacement: step 3, image 1 of 2 Holmes HEH8031 Control Buttons Replacement: step 3, image 2 of 2
    • Turn heater over so the controls are facing up.
    • Lift the front housing away from the back of the fan and slowly fold the front housing back down to the floor.
    • Internal wires are connected to both halves of the housing. Be careful when separating the housing.
  4. Holmes HEH8031 Control Buttons Replacement, Circuit Board Removal: step 4, image 1 of 1
    • Remove four 12mm Phillips #2 screws from the circuit board.
  5. Holmes HEH8031 Control Buttons Replacement, Control Buttons: step 5, image 1 of 3 Holmes HEH8031 Control Buttons Replacement, Control Buttons: step 5, image 2 of 3 Holmes HEH8031 Control Buttons Replacement, Control Buttons: step 5, image 3 of 3
    • Remove the two Phillips #2 12mm screws from the button retainer.
    • Lift the button retainer off.
    • Remove the interconnected buttons.
    • If the buttons are broken, replace them.
    • If the buttons are sticking, clean them in warm soapy water and allow to dry.
  6. Holmes HEH8031 Control Buttons Replacement: step 6, image 1 of 3 Holmes HEH8031 Control Buttons Replacement: step 6, image 2 of 3 Holmes HEH8031 Control Buttons Replacement: step 6, image 3 of 3
    • Using light finger pressure, carefully push the black plastic tabs off the white plastic hooks.
    • Remove the black plastic bracket out through the front of the heater housing.
    • Remove the two Phillips #2 12mm screws and remove the clear window from the black plastic bracket.
    • If the buttons were sticking, clean the black plastic bracket in warm soapy water and allow to dry.
    • If the clear window was dirty, clean it in warm soapy water and allow to dry.
Chris Shaffer
255 Reputation
2 Guides authored
IUPUI, Team 2-1, Baechle Fall 2016 Member of IUPUI, Team 2-1, Baechle Fall 2016
IUPUI-BAECHLE-F16S2G1
4 Members
16 Guides authored
0 Guide Comments
Past 24 Hours: 0
Past 7 Days: 3
Past 30 Days: 14
All Time: 644
