Holmes HEH8031 Fan Replacement
  1. Holmes HEH8031 Fan Replacement, Housing: step 1, image 1 of 1
    • Ensure the device is unplugged from the wall outlet.
  2. Holmes HEH8031 Fan Replacement: step 2, image 1 of 1
    • Remove eight 12-mm Phillips #2 screws from the back cover.
  3. Holmes HEH8031 Fan Replacement: step 3, image 1 of 2 Holmes HEH8031 Fan Replacement: step 3, image 2 of 2
    • Turn heater over so the controls are facing up.
    • Lift the front housing away from the back of the fan and slowly fold the front housing back down to the floor.
    • Internal wires are connected to both halves of the housing. Be careful when separating the housing.
  4. Holmes HEH8031 Fan Replacement, Circuit Board Removal: step 4, image 1 of 1
    • Remove four 12mm Phillips #2 screws from the circuit board.
  5. Holmes HEH8031 Fan Replacement, Circuit Board: step 5, image 1 of 3 Holmes HEH8031 Fan Replacement, Circuit Board: step 5, image 2 of 3 Holmes HEH8031 Fan Replacement, Circuit Board: step 5, image 3 of 3
    • Desolder the BLACK wires from the "AC-L" point and "T/S" point.
    • Learn how to solder and desolder connections here!
    • Desolder the WHITE wire from the "AC-N" point.
    • Desolder the RED wire from the "FAN-RED".
    • Desolder the GREY wire from the "24V" point.
    • Desolder the BROWN wires from "HEAT1," and "HEAT2" points.
    • Be sure to use desoldering wick when you remove the wire connections.
  6. Holmes HEH8031 Fan Replacement: step 6, image 1 of 2 Holmes HEH8031 Fan Replacement: step 6, image 2 of 2
    • Desolder the WHITE connector (attached to the GRAY wire coming of the thermostat) from the "NTC101" point.
  7. Holmes HEH8031 Fan Replacement, Fan: step 7, image 1 of 1
    • Remove two Phillips #2 12mm screws from housing
  8. Holmes HEH8031 Fan Replacement: step 8, image 1 of 1
    • Remove zip tie from wire with pliers
  9. Holmes HEH8031 Fan Replacement: step 9, image 1 of 1
    • Separate fan assembly from heating coil
Torben Eid
1 Reputation
1 Guide authored
IUPUI, Team 2-1, Baechle Fall 2016 Member of IUPUI, Team 2-1, Baechle Fall 2016
IUPUI-BAECHLE-F16S2G1
4 Members
16 Guides authored
0 Comments
Past 24 Hours: 0
Past 7 Days: 2
Past 30 Days: 10
All Time: 330
