Holmes HEH8031 Power Cord Replacement
  1. Holmes HEH8031 Power Cord Replacement, Housing: step 1, image 1 of 1
    • Ensure the device is unplugged from the wall outlet.
  2. Holmes HEH8031 Power Cord Replacement: step 2, image 1 of 1
    • Remove eight 12-mm Phillips #2 screws from the back cover.
  3. Holmes HEH8031 Power Cord Replacement: step 3, image 1 of 2 Holmes HEH8031 Power Cord Replacement: step 3, image 2 of 2
    • Turn heater over so the controls are facing up.
    • Lift the front housing away from the back of the fan and slowly fold the front housing back down to the floor.
    • Internal wires are connected to both halves of the housing. Be careful when separating the housing.
  4. Holmes HEH8031 Power Cord Replacement, Power Cord: step 4, image 1 of 3 Holmes HEH8031 Power Cord Replacement, Power Cord: step 4, image 2 of 3 Holmes HEH8031 Power Cord Replacement, Power Cord: step 4, image 3 of 3
    • Decrimp the wire nuts from both wire connections.
    • Remove wire nuts to expose wire strands.
    • Separate all connected wires.
  5. Holmes HEH8031 Power Cord Replacement: step 5, image 1 of 3 Holmes HEH8031 Power Cord Replacement: step 5, image 2 of 3 Holmes HEH8031 Power Cord Replacement: step 5, image 3 of 3
    • Pull on the cord from the outside of the heater with great finesse. At the same time, push the cord clamp out of the housing from the inside.
    • Separate the two halves of the cord clamp and remove from cord.
  6. Holmes HEH8031 Power Cord Replacement: step 6, image 1 of 2 Holmes HEH8031 Power Cord Replacement: step 6, image 2 of 2
    • Prepare the replacement cord by cutting the negative branch (black) at least 8 inches shorter than the positive branch (white).
    • Strip at least 3/4 inch of insulation from the cord to expose bare wire.
    • Twist wire ends to form a tight braid.
3 other people completed this guide.
Deanna Jack
333 Reputation
4 Guides authored
IUPUI, Team 2-1, Baechle Fall 2016 Member of IUPUI, Team 2-1, Baechle Fall 2016
IUPUI-BAECHLE-F16S2G1
4 Members
16 Guides authored
One Comment
Are there substitute power cord for Holmes HEH8031 power cord replacement?
Terri Allen - Reply
Past 24 Hours: 0
Past 7 Days: 2
Past 30 Days: 24
All Time: 1,950
