Holmes HEH8031 Safety Weight Replacement
  1. Holmes HEH8031 Safety Weight Replacement, Housing: step 1, image 1 of 1
    • Ensure the device is unplugged from the wall outlet.
  2. Holmes HEH8031 Safety Weight Replacement: step 2, image 1 of 1
    • Remove eight 12-mm Phillips #2 screws from the back cover.
  3. Holmes HEH8031 Safety Weight Replacement: step 3, image 1 of 2 Holmes HEH8031 Safety Weight Replacement: step 3, image 2 of 2
    • Turn heater over so the controls are facing up.
    • Lift the front housing away from the back of the fan and slowly fold the front housing back down to the floor.
    • Internal wires are connected to both halves of the housing. Be careful when separating the housing.
  4. Holmes HEH8031 Safety Weight Replacement, Circuit Board Removal: step 4, image 1 of 1
    • Remove four 12mm Phillips #2 screws from the circuit board.
  5. Holmes HEH8031 Safety Weight Replacement, Safety Weight: step 5, image 1 of 2 Holmes HEH8031 Safety Weight Replacement, Safety Weight: step 5, image 2 of 2
    • Remove wires from safety weight, as shown.
    • Pull upward on the blue connectors.
    • If connectors are tough to remove, try wiggling while pulling upward.
  6. Holmes HEH8031 Safety Weight Replacement: step 6, image 1 of 1
    • Unscrew the Phillips #2 10 mm screw from the safety weight on the rear housing panel.
Deanna Jack
333 Reputation
4 Guides authored
IUPUI, Team 2-1, Baechle Fall 2016 Member of IUPUI, Team 2-1, Baechle Fall 2016
IUPUI-BAECHLE-F16S2G1
4 Members
16 Guides authored
0 Comments
Past 24 Hours: 0
Past 7 Days: 1
Past 30 Days: 7
All Time: 552
