Homelite UT44172 Blades Replacement
  1. Homelite UT44172 Blades Replacement, Removing Screws: step 1, image 1 of 1
    • Remove the six 15.0 mm screws from the body of the device with a Phillips #2 screwdriver.
  2. Homelite UT44172 Blades Replacement, Removing Faceplate: step 2, image 1 of 1
    • Remove the face plate by lifting it away from the other half of the device. This will expose the interior.
  3. Homelite UT44172 Blades Replacement, Exposing Blade Components: step 3, image 1 of 2 Homelite UT44172 Blades Replacement, Exposing Blade Components: step 3, image 2 of 2
    • Use the Phillips #2 screwdriver to remove the four 10.0 mm screws on the bottom of the blades.
  4. Homelite UT44172 Blades Replacement, Replacing Blades: step 4, image 1 of 3 Homelite UT44172 Blades Replacement, Replacing Blades: step 4, image 2 of 3 Homelite UT44172 Blades Replacement, Replacing Blades: step 4, image 3 of 3
    • Remove the old blades by pulling them away from the gears and motor.
    • Be careful handling the blades. They are sharp.
Adam soto
301 Reputation
3 Guides authored
USF Tampa, Team 17-5, Watkins Winter 2015 Member of USF Tampa, Team 17-5, Watkins Winter 2015
USFT-WATKINS-W15S17G5
3 Members
4 Guides authored
0 Comments
Past 24 Hours: 0
Past 7 Days: 0
Past 30 Days: 8
All Time: 727
