Homelite UT44172 Operating Switch Replacement
  1. Homelite UT44172 Operating Switch Replacement, Opening Device: step 1, image 1 of 1
    • Use a Philips-head screwdriver to remove the six, 15 mm screws from the casing.
  2. Homelite UT44172 Operating Switch Replacement, Remove Faceplate: step 2, image 1 of 1
    • Remove the faceplate from the main body of the device, lift it and expose the inner mechanisms.
  3. Homelite UT44172 Operating Switch Replacement, Switch Removal: step 3, image 1 of 2 Homelite UT44172 Operating Switch Replacement, Switch Removal: step 3, image 2 of 2
    • Locate and remove the operating switch from the device.
  4. Homelite UT44172 Operating Switch Replacement, Spring Replacement: step 4, image 1 of 1
    • Replace the spring if it is deformed or broken.
    • Be careful that the wires do not get caught in the spring when replacing it.
Adam soto
301 Reputation
3 Guides authored
USF Tampa, Team 17-5, Watkins Winter 2015 Member of USF Tampa, Team 17-5, Watkins Winter 2015
USFT-WATKINS-W15S17G5
3 Members
4 Guides authored
0 Comments
Past 24 Hours: 1
Past 7 Days: 2
Past 30 Days: 5
All Time: 279
