Homelite UT44172 Plastic Casing Replacement
  1. Homelite UT44172 Plastic Casing Replacement, Opening Device: step 1, image 1 of 1
    • Remove the six 15 mm screws from the shear using a Phillips #2 screwdriver.
  2. Homelite UT44172 Plastic Casing Replacement, Remove Faceplate: step 2, image 1 of 2 Homelite UT44172 Plastic Casing Replacement, Remove Faceplate: step 2, image 2 of 2
    • Pull the faceplate away from the body of the device and replace it with the new faceplate.
    • Potential for device damage: Be sure to take caution of loose wires during the replacement process.
    • If the plate with the screw sockets was replaced, the wires will need to be put back into the the depressions on the new plate for the device to be closed up properly. See photo with the blades on the right for proper wire placement.
Adam soto
301 Reputation
3 Guides authored
USF Tampa, Team 17-5, Watkins Winter 2015 Member of USF Tampa, Team 17-5, Watkins Winter 2015
USFT-WATKINS-W15S17G5
3 Members
4 Guides authored
0 Guide Comments
Past 24 Hours: 0
Past 7 Days: 7
Past 30 Days: 25
All Time: 383
