Homelite UT44172 Safety Switch Replacement
  1. Homelite UT44172 Safety Switch Replacement, Opening the device: step 1, image 1 of 1
    • Remove the six 1.5 cm screws marked on the picture from the plastic casing with a Phillips #2 screwdriver.
  2. Homelite UT44172 Safety Switch Replacement, Remove Faceplate: step 2, image 1 of 1
    • Remove the faceplate to expose the inner mechanisms.
  3. Homelite UT44172 Safety Switch Replacement, Switch Removal: step 3, image 1 of 3 Homelite UT44172 Safety Switch Replacement, Switch Removal: step 3, image 2 of 3 Homelite UT44172 Safety Switch Replacement, Switch Removal: step 3, image 3 of 3
    • Remove the safety switch by pulling it away from the body of device.
    • Be careful not to lose the spring, which is under pressure and may fly out during removal.
  4. Homelite UT44172 Safety Switch Replacement, Spring Replacement: step 4, image 1 of 1
    • Inspect both the spring and the switch to see if either is deformed or damaged. If so, replace the damaged part with a new part.
    • During reassembly, gently move the inner wires out of the way so they do not get caught in the spring.
Daniel Endericavillacis
101 Reputation
1 Guide authored
USF Tampa, Team 17-5, Watkins Winter 2015 Member of USF Tampa, Team 17-5, Watkins Winter 2015
USFT-WATKINS-W15S17G5
3 Members
4 Guides authored
0 Guide Comments
Past 24 Hours: 0
Past 7 Days: 1
Past 30 Days: 10
All Time: 462
