Honda 3000 Watt Inverter Generator EU3000IS1AWK Battery Replacement
  1. Honda 3000 Watt Inverter Generator EU3000IS1AWK Battery Replacement, Remove the front cover: step 1, image 1 of 3 Honda 3000 Watt Inverter Generator EU3000IS1AWK Battery Replacement, Remove the front cover: step 1, image 2 of 3 Honda 3000 Watt Inverter Generator EU3000IS1AWK Battery Replacement, Remove the front cover: step 1, image 3 of 3
    • Use a 10 mm socket to remove the four capped nuts securing the front cover.
    • Remove the front cover.
  2. Honda 3000 Watt Inverter Generator EU3000IS1AWK Battery Replacement, Remove the battery: step 2, image 1 of 1
    • Use an 8 mm socket to disconnect the battery wires from the battery terminals.
    • Disconnect the black negative cable first to prevent the risk of shorting the battery.
    • During reassembly, connect the black negative cable first. Make sure you reconnect the wires in the correct polarity.
  3. Honda 3000 Watt Inverter Generator EU3000IS1AWK Battery Replacement: step 3, image 1 of 2 Honda 3000 Watt Inverter Generator EU3000IS1AWK Battery Replacement: step 3, image 2 of 2
    • Unclip the battery strap from the lower plate.
  4. Honda 3000 Watt Inverter Generator EU3000IS1AWK Battery Replacement: step 4, image 1 of 1
    • Remove the battery.
3 other people completed this guide.
Arthur Shi
258,916 Reputation
531 Guides authored
iFixit Member of iFixit
Staff
140 Members
18,078 Guides authored
0 Comments
Past 24 Hours: 4
Past 7 Days: 41
Past 30 Days: 210
All Time: 7,065
