Honda 3000 Watt Inverter Generator EU3000IS1AWK Stator Replacement
  1. Honda 3000 Watt Inverter Generator EU3000IS1AWK Stator Replacement, Disconnect the spark plug: step 1, image 1 of 2 Honda 3000 Watt Inverter Generator EU3000IS1AWK Stator Replacement, Disconnect the spark plug: step 1, image 2 of 2
    • Before you begin, make sure the generator is off and cool to the touch.
    • Use a large flathead screwdriver to unlock the maintenance cover.
    • Open the maintenance cover.
  2. Honda 3000 Watt Inverter Generator EU3000IS1AWK Stator Replacement: step 2, image 1 of 2 Honda 3000 Watt Inverter Generator EU3000IS1AWK Stator Replacement: step 2, image 2 of 2
    • Use a Phillips screwdriver to remove the screw securing the spark plug cover.
    • Remove the spark plug cover.
  3. Honda 3000 Watt Inverter Generator EU3000IS1AWK Stator Replacement: step 3, image 1 of 2 Honda 3000 Watt Inverter Generator EU3000IS1AWK Stator Replacement: step 3, image 2 of 2
    • Grab the plastic housing at the end of the spark plug wire.
    • Pull firmly to disconnect the wire from the spark plug.
  4. Honda 3000 Watt Inverter Generator EU3000IS1AWK Stator Replacement, Engage the fuel cutoff: step 4, image 1 of 2 Honda 3000 Watt Inverter Generator EU3000IS1AWK Stator Replacement, Engage the fuel cutoff: step 4, image 2 of 2
    • Turn the fuel valve to the cutoff position.
  5. Honda 3000 Watt Inverter Generator EU3000IS1AWK Stator Replacement, Remove the bushing nuts: step 5, image 1 of 1
    • Carefully tilt the generator to its side or back.
    • Use a 10 mm socket to remove the two nuts securing the front bushing mounts to the bottom of the generator.
    • Carefully tilt the generator back to an upright position.
  6. Honda 3000 Watt Inverter Generator EU3000IS1AWK Stator Replacement, Remove the air cleaner filter: step 6, image 1 of 3 Honda 3000 Watt Inverter Generator EU3000IS1AWK Stator Replacement, Remove the air cleaner filter: step 6, image 2 of 3 Honda 3000 Watt Inverter Generator EU3000IS1AWK Stator Replacement, Remove the air cleaner filter: step 6, image 3 of 3
    • Unlatch the four clips securing the air cleaner cover.
    • Remove the air cleaner cover.
  7. Honda 3000 Watt Inverter Generator EU3000IS1AWK Stator Replacement: step 7, image 1 of 2 Honda 3000 Watt Inverter Generator EU3000IS1AWK Stator Replacement: step 7, image 2 of 2
    • Remove the air cleaner filter from the housing.
  8. Honda 3000 Watt Inverter Generator EU3000IS1AWK Stator Replacement, Remove the air cleaner housing: step 8, image 1 of 2 Honda 3000 Watt Inverter Generator EU3000IS1AWK Stator Replacement, Remove the air cleaner housing: step 8, image 2 of 2
    • Pull and disconnect the breather tube from the top corner of the air cleaner housing.
  9. Honda 3000 Watt Inverter Generator EU3000IS1AWK Stator Replacement: step 9, image 1 of 2 Honda 3000 Watt Inverter Generator EU3000IS1AWK Stator Replacement: step 9, image 2 of 2
    • Pull and disconnect the lower tube from the bottom corner of the air cleaner housing.
  10. Honda 3000 Watt Inverter Generator EU3000IS1AWK Stator Replacement: step 10, image 1 of 1
    • Use a 10 mm socket to remove the three fasteners securing the air cleaner housing:
    • Two 10 mm nuts
    • During reassembly, tighten these nuts to 6.3 ft-lb (8.5 N-m).
    • One 10 mm bolt
  11. Honda 3000 Watt Inverter Generator EU3000IS1AWK Stator Replacement: step 11, image 1 of 2 Honda 3000 Watt Inverter Generator EU3000IS1AWK Stator Replacement: step 11, image 2 of 2
    • Pull the housing out slightly from its recess.
    • The housing still has tubes clipped to it.
  12. Honda 3000 Watt Inverter Generator EU3000IS1AWK Stator Replacement: step 12, image 1 of 1
    • Use a flathead screwdriver to pry and unclip the tube from the air cleaner housing.
  13. Honda 3000 Watt Inverter Generator EU3000IS1AWK Stator Replacement: step 13, image 1 of 1
    • Remove the air cleaner housing.
  14. Honda 3000 Watt Inverter Generator EU3000IS1AWK Stator Replacement, Remove the front cover: step 14, image 1 of 3 Honda 3000 Watt Inverter Generator EU3000IS1AWK Stator Replacement, Remove the front cover: step 14, image 2 of 3 Honda 3000 Watt Inverter Generator EU3000IS1AWK Stator Replacement, Remove the front cover: step 14, image 3 of 3
    • Use a 10 mm socket to remove the four capped nuts securing the front cover.
    • Remove the front cover.
  15. Honda 3000 Watt Inverter Generator EU3000IS1AWK Stator Replacement, Remove the handle: step 15, image 1 of 2 Honda 3000 Watt Inverter Generator EU3000IS1AWK Stator Replacement, Remove the handle: step 15, image 2 of 2
    • Use a 10 mm socket to remove the four bolts securing the handle to the frame.
  16. Honda 3000 Watt Inverter Generator EU3000IS1AWK Stator Replacement: step 16, image 1 of 2 Honda 3000 Watt Inverter Generator EU3000IS1AWK Stator Replacement: step 16, image 2 of 2
    • Remove the handle.
  17. Honda 3000 Watt Inverter Generator EU3000IS1AWK Stator Replacement, Remove the battery: step 17, image 1 of 1
    • Use an 8 mm socket to disconnect the battery wires from the battery terminals.
    • Disconnect the black negative cable first to prevent the risk of shorting the battery.
    • During reassembly, connect the black negative cable first. Make sure you reconnect the wires in the correct polarity.
  18. Honda 3000 Watt Inverter Generator EU3000IS1AWK Stator Replacement: step 18, image 1 of 2 Honda 3000 Watt Inverter Generator EU3000IS1AWK Stator Replacement: step 18, image 2 of 2
    • Unclip the battery strap from the lower plate.
  19. Honda 3000 Watt Inverter Generator EU3000IS1AWK Stator Replacement: step 19, image 1 of 1
    • Remove the battery.
  20. Honda 3000 Watt Inverter Generator EU3000IS1AWK Stator Replacement, Remove the lower plate: step 20, image 1 of 2 Honda 3000 Watt Inverter Generator EU3000IS1AWK Stator Replacement, Remove the lower plate: step 20, image 2 of 2
    • Use a 10 mm socket to remove the four capped nuts securing the lower plate.
    • Set these capped nuts apart. They look similar, but are smaller than the front cover nuts.
    • Remove the lower plate.
  21. Honda 3000 Watt Inverter Generator EU3000IS1AWK Stator Replacement, Unclip the fuse holder: step 21, image 1 of 2 Honda 3000 Watt Inverter Generator EU3000IS1AWK Stator Replacement, Unclip the fuse holder: step 21, image 2 of 2
    • Insert a flathead screwdriver into the top of the brown fuse clip in order to release the fuse holder.
    • Detach the fuse holder from the brown clip.
  22. Honda 3000 Watt Inverter Generator EU3000IS1AWK Stator Replacement, Disconnect the choke cable: step 22, image 1 of 2 Honda 3000 Watt Inverter Generator EU3000IS1AWK Stator Replacement, Disconnect the choke cable: step 22, image 2 of 2
    • Use pliers to lift and disconnect the choke cable from the choke stay.
    • During reassembly, be sure to test the choke to ensure that it is properly connected.
  23. Honda 3000 Watt Inverter Generator EU3000IS1AWK Stator Replacement, Remove the fuel cutoff switch: step 23, image 1 of 1
    • Use a long shaft Phillips screwdriver to remove the deeply recessed screw securing the fuel cutoff switch.
    • Be careful not to turn the fuel cutoff switch while you remove the screw.
  24. Honda 3000 Watt Inverter Generator EU3000IS1AWK Stator Replacement: step 24, image 1 of 2 Honda 3000 Watt Inverter Generator EU3000IS1AWK Stator Replacement: step 24, image 2 of 2
    • Remove the fuel cutoff switch.
    • During reassembly, be sure to test the switch to ensure that it is properly installed.
  25. Honda 3000 Watt Inverter Generator EU3000IS1AWK Stator Replacement, Loosen the control panel: step 25, image 1 of 1
    • Use a 10 mm socket to remove the four bolts securing the control panel.
  26. Honda 3000 Watt Inverter Generator EU3000IS1AWK Stator Replacement: step 26, image 1 of 2 Honda 3000 Watt Inverter Generator EU3000IS1AWK Stator Replacement: step 26, image 2 of 2
    • Carefully tilt the control panel downwards.
    • The control panel will still be connected to many wires and cables. Be careful not to strain any of the connected wires.
  27. Honda 3000 Watt Inverter Generator EU3000IS1AWK Stator Replacement, Remove the inverter: step 27, image 1 of 2 Honda 3000 Watt Inverter Generator EU3000IS1AWK Stator Replacement, Remove the inverter: step 27, image 2 of 2
    • Remove the following bolts securing the inverter:
    • One 8 mm ground bolt
    • Three 10 mm bolts (one behind the control panel)
  28. Honda 3000 Watt Inverter Generator EU3000IS1AWK Stator Replacement: step 28, image 1 of 3 Honda 3000 Watt Inverter Generator EU3000IS1AWK Stator Replacement: step 28, image 2 of 3 Honda 3000 Watt Inverter Generator EU3000IS1AWK Stator Replacement: step 28, image 3 of 3
    • Reach behind the inverter along the edges and disconnect the six connectors from the back of the inverter.
    • All the connectors use locking tabs, so you will have to squeeze them in order to release them.
    • The third image shows the locations of all six sockets on the inverter.
    • Reassembly tip: Every socket on the inverter is different, so you can't plug something into the wrong place. Do not force the connectors into their sockets.
  29. Honda 3000 Watt Inverter Generator EU3000IS1AWK Stator Replacement: step 29, image 1 of 2 Honda 3000 Watt Inverter Generator EU3000IS1AWK Stator Replacement: step 29, image 2 of 2
    • Remove the inverter.
  30. Honda 3000 Watt Inverter Generator EU3000IS1AWK Stator Replacement, Transfer the rubber mounts: step 30, image 1 of 2 Honda 3000 Watt Inverter Generator EU3000IS1AWK Stator Replacement, Transfer the rubber mounts: step 30, image 2 of 2
    • If you are replacing the inverter and the replacement did not come with rubber mounts, follow the next two steps to transfer them over.
    • Use a screwdriver to push the metal collar out of the center of the rubber mount.
  31. Honda 3000 Watt Inverter Generator EU3000IS1AWK Stator Replacement: step 31, image 1 of 2 Honda 3000 Watt Inverter Generator EU3000IS1AWK Stator Replacement: step 31, image 2 of 2
    • Squeeze the mount and remove it from the inverter.
    • Repeat the procedure with the remaining mounts and transfer them to the replacement inverter.
  32. Honda 3000 Watt Inverter Generator EU3000IS1AWK Stator Replacement, Remove the rear cover: step 32, image 1 of 2 Honda 3000 Watt Inverter Generator EU3000IS1AWK Stator Replacement, Remove the rear cover: step 32, image 2 of 2
    • Use a 10 mm socket to remove the four capped nuts securing the rear cover.
    • Remove the rear cover.
  33. Honda 3000 Watt Inverter Generator EU3000IS1AWK Stator Replacement: step 33, image 1 of 2 Honda 3000 Watt Inverter Generator EU3000IS1AWK Stator Replacement: step 33, image 2 of 2
    • Use a 10 mm socket to remove the four bolts securing the muffler protector.
    • Remove the muffler protector.
  34. Honda 3000 Watt Inverter Generator EU3000IS1AWK Stator Replacement, Loosen the main cover: step 34, image 1 of 2 Honda 3000 Watt Inverter Generator EU3000IS1AWK Stator Replacement, Loosen the main cover: step 34, image 2 of 2
    • Pull the muffler shroud slightly away from the frame to access the top frame bolts.
    • Use a 10 mm socket to remove the two bolts securing the top edge of the cover.
  35. Honda 3000 Watt Inverter Generator EU3000IS1AWK Stator Replacement: step 35, image 1 of 1
    • Use a 10 mm socket to remove the three bolts securing the front edge of the cover.
  36. Honda 3000 Watt Inverter Generator EU3000IS1AWK Stator Replacement: step 36, image 1 of 2 Honda 3000 Watt Inverter Generator EU3000IS1AWK Stator Replacement: step 36, image 2 of 2
    • Use a 10 mm socket to remove the four bolts from the maintenance cover side.
    • Remove the maintenance cover.
  37. Honda 3000 Watt Inverter Generator EU3000IS1AWK Stator Replacement: step 37, image 1 of 3 Honda 3000 Watt Inverter Generator EU3000IS1AWK Stator Replacement: step 37, image 2 of 3 Honda 3000 Watt Inverter Generator EU3000IS1AWK Stator Replacement: step 37, image 3 of 3
    • Carefully peel the maintenance cover seal from the frame.
  38. Honda 3000 Watt Inverter Generator EU3000IS1AWK Stator Replacement: step 38, image 1 of 1
    • Use an 8 mm socket to remove the two bolts securing the non-access side of the cover.
  39. Honda 3000 Watt Inverter Generator EU3000IS1AWK Stator Replacement: step 39, image 1 of 2 Honda 3000 Watt Inverter Generator EU3000IS1AWK Stator Replacement: step 39, image 2 of 2
    • Unscrew the gas cap.
  40. Honda 3000 Watt Inverter Generator EU3000IS1AWK Stator Replacement: step 40, image 1 of 3 Honda 3000 Watt Inverter Generator EU3000IS1AWK Stator Replacement: step 40, image 2 of 3 Honda 3000 Watt Inverter Generator EU3000IS1AWK Stator Replacement: step 40, image 3 of 3
    • Lift the cover up slightly to free it from the frame and slide it back by a few inches.
  41. Honda 3000 Watt Inverter Generator EU3000IS1AWK Stator Replacement, Disassembly tip: step 41, image 1 of 1
    • At this point, it may be helpful to temporarily re-attach the control panel back onto the front frame with some 10 mm bolts.
  42. Honda 3000 Watt Inverter Generator EU3000IS1AWK Stator Replacement, Release the choke cable bushing: step 42, image 1 of 3 Honda 3000 Watt Inverter Generator EU3000IS1AWK Stator Replacement, Release the choke cable bushing: step 42, image 2 of 3 Honda 3000 Watt Inverter Generator EU3000IS1AWK Stator Replacement, Release the choke cable bushing: step 42, image 3 of 3
    • Lift up and release the choke cable's rubber bushing from the choke stay.
    • During reassembly, make sure that the choke cable's rubber bushing is properly seated on the choke stay.
  43. Honda 3000 Watt Inverter Generator EU3000IS1AWK Stator Replacement, Loosen the front frame: step 43, image 1 of 1
    • Use a 10 mm socket to remove the three frame bolts securing the bottom of the front frame.
  44. Honda 3000 Watt Inverter Generator EU3000IS1AWK Stator Replacement: step 44, image 1 of 1
    • Use a 10 mm socket to remove the four bolts securing the top of the front frame.
  45. Honda 3000 Watt Inverter Generator EU3000IS1AWK Stator Replacement: step 45, image 1 of 2 Honda 3000 Watt Inverter Generator EU3000IS1AWK Stator Replacement: step 45, image 2 of 2
    • Pull and disconnect the starter motor's black barrel and white barrel connectors.
    • During reassembly, the wires should be reconnected to their respective colors.
  46. Honda 3000 Watt Inverter Generator EU3000IS1AWK Stator Replacement: step 46, image 1 of 1
    • Unplug the two-wire oil switch connector.
  47. Honda 3000 Watt Inverter Generator EU3000IS1AWK Stator Replacement: step 47, image 1 of 1
    • Unplug the four-wire regulator connector from the bottom edge of the control panel.
  48. Honda 3000 Watt Inverter Generator EU3000IS1AWK Stator Replacement: step 48, image 1 of 2 Honda 3000 Watt Inverter Generator EU3000IS1AWK Stator Replacement: step 48, image 2 of 2
    • Unplug the two winding connectors.
    • These connectors all have brown wiring in black sleeves.
  49. Honda 3000 Watt Inverter Generator EU3000IS1AWK Stator Replacement: step 49, image 1 of 3 Honda 3000 Watt Inverter Generator EU3000IS1AWK Stator Replacement: step 49, image 2 of 3 Honda 3000 Watt Inverter Generator EU3000IS1AWK Stator Replacement: step 49, image 3 of 3
    • Insert the edge of a large flathead screwdriver under the bottom edge of the front frame.
    • Pry up and outward to release the bottom edge of the front frame.
  50. Honda 3000 Watt Inverter Generator EU3000IS1AWK Stator Replacement: step 50, image 1 of 2 Honda 3000 Watt Inverter Generator EU3000IS1AWK Stator Replacement: step 50, image 2 of 2
    • Carefully swing the front frame to the right side of the generator.
    • While the images show the control panel unbolted from the front frame, you can keep it bolted to the frame.
    • The front frame is still connected to the generator by many wires. Be careful not to strain any wires.
  51. Honda 3000 Watt Inverter Generator EU3000IS1AWK Stator Replacement, Remove the recoil starter: step 51, image 1 of 1
    • Use a 10 mm socket to remove the three bolts securing the recoil starter.
  52. Honda 3000 Watt Inverter Generator EU3000IS1AWK Stator Replacement: step 52, image 1 of 3 Honda 3000 Watt Inverter Generator EU3000IS1AWK Stator Replacement: step 52, image 2 of 3 Honda 3000 Watt Inverter Generator EU3000IS1AWK Stator Replacement: step 52, image 3 of 3
    • Remove the recoil starter and move it out of the way.
    • Be careful not to lose the metal collar in each of the recoil starter's bolt holes.
  53. Honda 3000 Watt Inverter Generator EU3000IS1AWK Stator Replacement, Remove the starter pulley: step 53, image 1 of 2 Honda 3000 Watt Inverter Generator EU3000IS1AWK Stator Replacement, Remove the starter pulley: step 53, image 2 of 2
    • Use a 10 mm socket to remove the two bolts securing the starter pulley.
    • Remove the starter pulley.
  54. Honda 3000 Watt Inverter Generator EU3000IS1AWK Stator Replacement, Remove the air cleaner housing bracket: step 54, image 1 of 2 Honda 3000 Watt Inverter Generator EU3000IS1AWK Stator Replacement, Remove the air cleaner housing bracket: step 54, image 2 of 2
    • Use a 10 mm socket to remove the bolt securing the air cleaner housing bracket.
    • Remove the air cleaner housing bracket.
  55. Honda 3000 Watt Inverter Generator EU3000IS1AWK Stator Replacement, Remove the petcock assembly: step 55, image 1 of 2 Honda 3000 Watt Inverter Generator EU3000IS1AWK Stator Replacement, Remove the petcock assembly: step 55, image 2 of 2
    • Fuel may leak out when you disconnect this hose. Be ready to catch any spillage.
    • Use pliers to squeeze and loosen the hose clamp securing the carburetor fuel line.
    • Pull and disconnect the carburetor fuel line from the petcock assembly.
  56. Honda 3000 Watt Inverter Generator EU3000IS1AWK Stator Replacement: step 56, image 1 of 2 Honda 3000 Watt Inverter Generator EU3000IS1AWK Stator Replacement: step 56, image 2 of 2
    • Be sure to drain the fuel tank before you perform this step.
    • Use a large crescent wrench to loosen the petcock assembly from the fuel tank.
    • Residual fuel will leak out as you remove the petcock assembly. Be ready to catch any spillage.
    • Remove the petcock assembly.
  57. Honda 3000 Watt Inverter Generator EU3000IS1AWK Stator Replacement, Drain the carburetor bowl: step 57, image 1 of 3 Honda 3000 Watt Inverter Generator EU3000IS1AWK Stator Replacement, Drain the carburetor bowl: step 57, image 2 of 3 Honda 3000 Watt Inverter Generator EU3000IS1AWK Stator Replacement, Drain the carburetor bowl: step 57, image 3 of 3
    • Place a container below the carburetor drain tube to catch the excess fuel.
    • The carburetor drain screw is located at the bottom of the carburetor.
    • Use a flathead screwdriver to loosen the brass fuel drain screw until fuel begins to drain out of the carburetor.
    • Once you drain the fuel bowl, re-tighten the fuel drain screw.
  58. Honda 3000 Watt Inverter Generator EU3000IS1AWK Stator Replacement, Remove the carburetor: step 58, image 1 of 1
  59. Honda 3000 Watt Inverter Generator EU3000IS1AWK Stator Replacement: step 59, image 1 of 1
    • Remove the choke stay.
  60. Honda 3000 Watt Inverter Generator EU3000IS1AWK Stator Replacement: step 60, image 1 of 1
  61. Honda 3000 Watt Inverter Generator EU3000IS1AWK Stator Replacement: step 61, image 1 of 3 Honda 3000 Watt Inverter Generator EU3000IS1AWK Stator Replacement: step 61, image 2 of 3 Honda 3000 Watt Inverter Generator EU3000IS1AWK Stator Replacement: step 61, image 3 of 3
    • Slide the carburetor off the mounting bolts.
    • During reassembly, use the third photo as a reference for how to route the carburetor tubes.
  62. Honda 3000 Watt Inverter Generator EU3000IS1AWK Stator Replacement: step 62, image 1 of 1
    • Disconnect the throttle control connector from the top of the carburetor.
    • Unwrap the throttle control wires from the carburetor.
  63. Honda 3000 Watt Inverter Generator EU3000IS1AWK Stator Replacement: step 63, image 1 of 1
    • Remove the carburetor.
  64. Honda 3000 Watt Inverter Generator EU3000IS1AWK Stator Replacement: step 64, image 1 of 1
  65. Honda 3000 Watt Inverter Generator EU3000IS1AWK Stator Replacement: step 65, image 1 of 1
    • Remove the carburetor insulator.
  66. Honda 3000 Watt Inverter Generator EU3000IS1AWK Stator Replacement: step 66, image 1 of 1
  67. Honda 3000 Watt Inverter Generator EU3000IS1AWK Stator Replacement, Remove the fan cover: step 67, image 1 of 3 Honda 3000 Watt Inverter Generator EU3000IS1AWK Stator Replacement, Remove the fan cover: step 67, image 2 of 3 Honda 3000 Watt Inverter Generator EU3000IS1AWK Stator Replacement, Remove the fan cover: step 67, image 3 of 3
    • Use a 10 mm socket to remove the seven bolts securing the fan cover:
    • Four bolts on top
    • One recessed bolt in the bottom left corner
    • Two bolts in the bottom right corner
    • During reassembly, be sure to reattach the ground wire.
  68. Honda 3000 Watt Inverter Generator EU3000IS1AWK Stator Replacement: step 68, image 1 of 1
    • Use a 12 mm socket to remove the mounting nuts securing the front bushings.
  69. Honda 3000 Watt Inverter Generator EU3000IS1AWK Stator Replacement: step 69, image 1 of 2 Honda 3000 Watt Inverter Generator EU3000IS1AWK Stator Replacement: step 69, image 2 of 2
    • Insert a pry bar underneath the fan cover.
    • Pry upwards to lift the generator assembly slightly.
  70. Honda 3000 Watt Inverter Generator EU3000IS1AWK Stator Replacement: step 70, image 1 of 3 Honda 3000 Watt Inverter Generator EU3000IS1AWK Stator Replacement: step 70, image 2 of 3 Honda 3000 Watt Inverter Generator EU3000IS1AWK Stator Replacement: step 70, image 3 of 3
    • As you lift the generator assembly with the pry bar, maneuver and remove the two generator mounts from their recess.
  71. Honda 3000 Watt Inverter Generator EU3000IS1AWK Stator Replacement: step 71, image 1 of 1
    • Use a 10 mm socket to remove the long bolt from the fan cover.
  72. Honda 3000 Watt Inverter Generator EU3000IS1AWK Stator Replacement: step 72, image 1 of 2 Honda 3000 Watt Inverter Generator EU3000IS1AWK Stator Replacement: step 72, image 2 of 2
    • Carefully pull the fan cover away from the generator assembly.
    • During reassembly, make sure that the cord grommet is properly slotted into the fan cover.
  73. Honda 3000 Watt Inverter Generator EU3000IS1AWK Stator Replacement: step 73, image 1 of 2 Honda 3000 Watt Inverter Generator EU3000IS1AWK Stator Replacement: step 73, image 2 of 2
    • The fan cover is a tight fit. You may need to push the gas tank upwards as you maneuver the fan cover out.
    • Remove the fan cover.
  74. Honda 3000 Watt Inverter Generator EU3000IS1AWK Stator Replacement, Remove the cooling fan: step 74, image 1 of 1
    • Remove the cooling fan.
  75. Honda 3000 Watt Inverter Generator EU3000IS1AWK Stator Replacement, Remove the rotor: step 75, image 1 of 1
    • Use a 19 mm socket to remove the nut securing the rotor to the generator shaft.
    • During reassembly, tighten this nut to 55 ft-lb (74 N-m).
  76. Honda 3000 Watt Inverter Generator EU3000IS1AWK Stator Replacement: step 76, image 1 of 2 Honda 3000 Watt Inverter Generator EU3000IS1AWK Stator Replacement: step 76, image 2 of 2
    • Attach a flywheel puller to the rotor and use it to loosen the rotor.
    • To prevent the rotor from spinning, insert a flathead screwdriver into one of the rotor slots and brace it against the ignition coil bracket.
    • Be careful not to insert the screwdriver too deeply into the slot, or you will damage the stator.
  77. Honda 3000 Watt Inverter Generator EU3000IS1AWK Stator Replacement: step 77, image 1 of 3 Honda 3000 Watt Inverter Generator EU3000IS1AWK Stator Replacement: step 77, image 2 of 3 Honda 3000 Watt Inverter Generator EU3000IS1AWK Stator Replacement: step 77, image 3 of 3
    • Remove the rotor.
    • Be careful not to lose the Woodruff key.
    • During reassembly, be sure to align the rotor to the Woodruff key.
    • After you install the replacement rotor, rotate it by hand to make sure that the rotor does not rub against the stator.
  78. Honda 3000 Watt Inverter Generator EU3000IS1AWK Stator Replacement, Loosen the ignition coil: step 78, image 1 of 2 Honda 3000 Watt Inverter Generator EU3000IS1AWK Stator Replacement, Loosen the ignition coil: step 78, image 2 of 2
    • Use a 10 mm socket to remove the two bolts securing the ignition coil.
    • Loosen the ignition coil from the frame.
  79. Honda 3000 Watt Inverter Generator EU3000IS1AWK Stator Replacement, Remove the ignition coil bracket: step 79, image 1 of 2 Honda 3000 Watt Inverter Generator EU3000IS1AWK Stator Replacement, Remove the ignition coil bracket: step 79, image 2 of 2
    • Use a 10 mm socket to remove the two bolts securing the ignition coil bracket.
    • Remove the ignition coil bracket.
  80. Honda 3000 Watt Inverter Generator EU3000IS1AWK Stator Replacement, Remove the stator: step 80, image 1 of 1
    • Use a 4 mm hex key to remove the four bolts securing the stator.
    • During reassembly, tighten these bolts to 8 lb-ft (11 N-m).
  81. Honda 3000 Watt Inverter Generator EU3000IS1AWK Stator Replacement: step 81, image 1 of 2 Honda 3000 Watt Inverter Generator EU3000IS1AWK Stator Replacement: step 81, image 2 of 2
    • Remove the stator.
2 other people completed this guide.
Arthur Shi
258,916 Reputation
531 Guides authored
iFixit Member of iFixit
Staff
140 Members
18,078 Guides authored
2 Comments
Hy How Are You
I Have Many Time Open EU30is or Eu65is . Thanks For Sharing in Picture Wire Every Steps. I Had Not Agree Your Step, No 76.
Step No.76 (Be careful not to insert the screwdriver too deeply into the slot, or you will damage the stator.)
Not Agree, Please Use Fly Wheel Stoper Holder. or Special Tool, Thank You.
Allah Blessings You.
asif basheer - Reply
I too think step 76 is a recipe for destroying the flywheel. The shock and distortion of using a flywheel puller in this manner will cause the magnets to break away from the flywheel. Instead undo the flywheel bolt a few turns and use a thick bar of metal with 7mm holes to coincide with the recoil cup holes in the flywheel. Use bolts through the bar into the threaded m6 recoil cup holes in the flywheel to put a bit of pressure on the flywheel nut with the bar. Then tap the bar sharply with a hammer above the flywheel nut. The flywheel will disengage easily. While doing this be careful that the bolts do not go far enough into the flywheel to damage the windings. You should be able to align the threaded holes with the heads of the bolts holding the stator to protect against this possibility.
Donchampignon - Reply
Past 24 Hours: 2
Past 7 Days: 11
Past 30 Days: 107
All Time: 3,814
