Honda 6500 Watt Generator EG6500CL AT Brush Assembly Replacement
  1. Honda 6500 Watt Generator EG6500CL AT Brush Assembly Replacement, Honda 6500 Watt Generator EG6500CL AT Safety Precautions: step 1, image 1 of 2 Honda 6500 Watt Generator EG6500CL AT Brush Assembly Replacement, Honda 6500 Watt Generator EG6500CL AT Safety Precautions: step 1, image 2 of 2
    • Before you work on the device, make sure to switch the engine off.
    • Switch the circuit breaker off.
  2. Honda 6500 Watt Generator EG6500CL AT Brush Assembly Replacement, Disconnect the spark plug: step 2, image 1 of 2 Honda 6500 Watt Generator EG6500CL AT Brush Assembly Replacement, Disconnect the spark plug: step 2, image 2 of 2
    • Grab the plastic housing at the end of the spark plug wire.
    • Pull firmly to disconnect the wire from the spark plug.
  3. Honda 6500 Watt Generator EG6500CL AT Brush Assembly Replacement: step 3, image 1 of 2 Honda 6500 Watt Generator EG6500CL AT Brush Assembly Replacement: step 3, image 2 of 2
    • Twist the fuel valve clockwise into the cutoff position.
  4. Honda 6500 Watt Generator EG6500CL AT Brush Assembly Replacement, Remove the generator cover: step 4, image 1 of 1
    • Use a Phillips screwdriver to remove the two screws securing the generator cover.
  5. Honda 6500 Watt Generator EG6500CL AT Brush Assembly Replacement: step 5, image 1 of 2 Honda 6500 Watt Generator EG6500CL AT Brush Assembly Replacement: step 5, image 2 of 2
    • Remove the generator cover.
  6. Honda 6500 Watt Generator EG6500CL AT Brush Assembly Replacement, Remove the brush assembly: step 6, image 1 of 2 Honda 6500 Watt Generator EG6500CL AT Brush Assembly Replacement, Remove the brush assembly: step 6, image 2 of 2
    • Squeeze and disconnect the stator connector from the wiring harness.
  7. Honda 6500 Watt Generator EG6500CL AT Brush Assembly Replacement: step 7, image 1 of 2 Honda 6500 Watt Generator EG6500CL AT Brush Assembly Replacement: step 7, image 2 of 2
    • Use a 10 mm socket to remove the bolt securing the brush assembly.
    • Pull the brush assembly out slightly from its recess.
  8. Honda 6500 Watt Generator EG6500CL AT Brush Assembly Replacement: step 8, image 1 of 2 Honda 6500 Watt Generator EG6500CL AT Brush Assembly Replacement: step 8, image 2 of 2
    • Disconnect the two spade connectors from the brush assembly.
  9. Honda 6500 Watt Generator EG6500CL AT Brush Assembly Replacement: step 9, image 1 of 2 Honda 6500 Watt Generator EG6500CL AT Brush Assembly Replacement: step 9, image 2 of 2
    • Remove the brush assembly.
    • During reassembly, use the second photo as reference for how to wire the brush assembly.
Arthur Shi
258,916 Reputation
531 Guides authored
iFixit Member of iFixit
Staff
140 Members
18,078 Guides authored
0 Comments
Past 24 Hours: 2
Past 7 Days: 2
Past 30 Days: 18
All Time: 705
