Honda Accord Car Key Remote
  1. Honda Accord Car Key Remote, Replacing the battery: step 1, image 1 of 2 Honda Accord Car Key Remote, Replacing the battery: step 1, image 2 of 2
    • Locate the screw in the middle of your car key.
    • Make sure you have the following tools - Tri-point Screwdriver - CR2032 Battery
  2. Honda Accord Car Key Remote: step 2, image 1 of 1
    • With your screwdriver, begin to screw in a counter-clockwise motion.
  3. Honda Accord Car Key Remote: step 3, image 1 of 1
    • Each key should have a small gap. Locate this gap on the side of your key.
    • After you have taken off the screw, place the small screw somewhere safe. Then with the same screwdriver or a flathead screwdriver, you want to apply pressure to the small gap to pop it open.
  4. Honda Accord Car Key Remote: step 4, image 1 of 3 Honda Accord Car Key Remote: step 4, image 2 of 3 Honda Accord Car Key Remote: step 4, image 3 of 3
    • This is an example of how the key should look after you pop it open.
  5. Honda Accord Car Key Remote: step 5, image 1 of 1
    • Do not touch the other half of the key
    • After popping open the key, the battery should be located on the left half of the key.
  6. Honda Accord Car Key Remote: step 6, image 1 of 1
    • Apply pressure with the flathead screwdriver, and the battery should pop out once again.
  7. Honda Accord Car Key Remote: step 7, image 1 of 2 Honda Accord Car Key Remote: step 7, image 2 of 2
    • swap the old battery with the new battery
    • Make sure the smooth part of the battery is facing inside and not facing outwards as shown on the picture
  8. Honda Accord Car Key Remote: step 8, image 1 of 1
    • Lastly, place the key back together and screw the middle part back with the tri-point screwdriver.
Emerson Corado
157 Reputation
1 Guide authored
1 Guide Comment
You listed the wrong battery. It uses a CR1620 not a CR2032. Your picture even shows the correct battery. Also I believe it is a P000 screwdriver, that is what fit my 2013 Accord key.
Mark Fox - Reply Share
Past 24 Hours: 1
Past 7 Days: 5
Past 30 Days: 30
All Time: 593
