Honda CSC29 Rectifer Bridge Assembly Replacement
  1. Honda CSC29 Rectifer Bridge Assembly Replacement, Alternator Front Cover: step 1, image 1 of 3 Honda CSC29 Rectifer Bridge Assembly Replacement, Alternator Front Cover: step 1, image 2 of 3 Honda CSC29 Rectifer Bridge Assembly Replacement, Alternator Front Cover: step 1, image 3 of 3
    • Remove 4, 7.9mm nuts using a 7.9mm socket driver head
    • One of the nuts is placed underneath the L-Bracket. Remove the L-Bracket and the 3 circled nuts before attempting to remove the remaining nut
    • There are two covers that need to be removed from the alternator. This step describes how to remove the back cover.
  2. Honda CSC29 Rectifer Bridge Assembly Replacement: step 2, image 1 of 3 Honda CSC29 Rectifer Bridge Assembly Replacement: step 2, image 2 of 3 Honda CSC29 Rectifer Bridge Assembly Replacement: step 2, image 3 of 3
    • Pull cover off the body of the alternator
    • Once you have done this, you should be able to see the internal components of the alternator, particularly the bridge assembly that houses the rectifier, voltage regulator and brushes.
  3. Honda CSC29 Rectifer Bridge Assembly Replacement, Removing the brush assembly.: step 3, image 1 of 3 Honda CSC29 Rectifer Bridge Assembly Replacement, Removing the brush assembly.: step 3, image 2 of 3 Honda CSC29 Rectifer Bridge Assembly Replacement, Removing the brush assembly.: step 3, image 3 of 3
    • With the alternator cover removed, use a #2 Phillips screwdriver to remove the two, 6 mm screws that hold the brush cover in place.
    • Remove the brush cover assembly from the alternator. You might need to insert a needle in the small hole to separate the brushes from the rotor. Pull it out without using much force to avoid damage.
    • Avoid disconnecting wires unless otherwise specified!
  4. Honda CSC29 Rectifer Bridge Assembly Replacement: step 4, image 1 of 3 Honda CSC29 Rectifer Bridge Assembly Replacement: step 4, image 2 of 3 Honda CSC29 Rectifer Bridge Assembly Replacement: step 4, image 3 of 3
    • Use a #2 Phillips screwdriver to remove the two 6mm screws holding down the voltage regulator
    • There are three screws that attach the voltage regulator to the bridge assembly. One of these screws was removed in the previous step.
  5. Honda CSC29 Rectifer Bridge Assembly Replacement: step 5, image 1 of 1
    • Locate and unscrew the 3, 6mm screws holding the bridge assembly in place
    • There are 4 screws attaching the bridge assembly to the alternator. One of these screws were removed in the previous step.
  6. Honda CSC29 Rectifer Bridge Assembly Replacement: step 6, image 1 of 2 Honda CSC29 Rectifer Bridge Assembly Replacement: step 6, image 2 of 2
    • Locate the copper leads connecting the stator to the bridge assembly. There are 3 sets of 2 leads on the perimeter of the bridge, making 6 leads total.
    • These leads must be cut in order to remove the bridge from the alternator. These leads will have to be soldered back together on reassembly. Keep the cut as clean as possible.
    • Use wire cutters to cut all 6 of the leads on the perimeter of the bridge.
  7. Honda CSC29 Rectifer Bridge Assembly Replacement: step 7, image 1 of 3 Honda CSC29 Rectifer Bridge Assembly Replacement: step 7, image 2 of 3 Honda CSC29 Rectifer Bridge Assembly Replacement: step 7, image 3 of 3
    • If necessary, use a pry bar to gently raise the top of the bridge assembly off the alternator
    • Be extremely careful with the pry bar. Excessive force will damage the bridge assembly.
    • Make sure the cut ends of the copper leads are straight to make bridge assembly easier to pull off.
  8. Honda CSC29 Rectifer Bridge Assembly Replacement: step 8, image 1 of 3 Honda CSC29 Rectifer Bridge Assembly Replacement: step 8, image 2 of 3 Honda CSC29 Rectifer Bridge Assembly Replacement: step 8, image 3 of 3
    • Remove the lower section of the bridge assembly
    • Use of a pry bar may be necessary. Be gentle.
4 other people completed this guide.
Chad Lagomarsino
569 Reputation
2 Guides authored
Cal Poly, Team 25-1, Maness Spring 2016 Member of Cal Poly, Team 25-1, Maness Spring 2016
CPSU-MANESS-S16S25G1
4 Members
15 Guides authored
0 Guide Comments
Past 24 Hours: 1
Past 7 Days: 10
Past 30 Days: 33
All Time: 2,133
