Honda Lawn Mower HRS216K6 PKAA Flywheel Key Replacement
  1. Honda Lawn Mower HRS216K6 PKAA Flywheel Key Replacement, Disconnect the spark plug: step 1, image 1 of 2 Honda Lawn Mower HRS216K6 PKAA Flywheel Key Replacement, Disconnect the spark plug: step 1, image 2 of 2
    • Before you begin, make sure the engine is switched off and cool to the touch.
    • Grab the plastic housing at the end of the spark plug wire and pull firmly to disconnect it.
  2. Honda Lawn Mower HRS216K6 PKAA Flywheel Key Replacement, Restrict fuel flow: step 2, image 1 of 1
    • Turn the fuel cutoff valve to the off position to restrict fuel flow during disassembly.
    • Turn the fuel cutoff valve clockwise so the handle becomes vertical.
  3. Honda Lawn Mower HRS216K6 PKAA Flywheel Key Replacement, Disconnect the fuel tank: step 3, image 1 of 3 Honda Lawn Mower HRS216K6 PKAA Flywheel Key Replacement, Disconnect the fuel tank: step 3, image 2 of 3 Honda Lawn Mower HRS216K6 PKAA Flywheel Key Replacement, Disconnect the fuel tank: step 3, image 3 of 3
    • Use needle nose pliers to compress and slide the tube clamp away from the cutoff valve's fitting.
  4. Honda Lawn Mower HRS216K6 PKAA Flywheel Key Replacement: step 4, image 1 of 2 Honda Lawn Mower HRS216K6 PKAA Flywheel Key Replacement: step 4, image 2 of 2
    • Residual fuel may leak out of this hose. Be ready to catch any spillage.
    • Disconnect the fuel line from the cutoff valve.
  5. Honda Lawn Mower HRS216K6 PKAA Flywheel Key Replacement, Disconnect the brake cable: step 5, image 1 of 1
    • Use needle nose pliers to squeeze the two locking tabs on the brake cable latch.
  6. Honda Lawn Mower HRS216K6 PKAA Flywheel Key Replacement: step 6, image 1 of 3 Honda Lawn Mower HRS216K6 PKAA Flywheel Key Replacement: step 6, image 2 of 3 Honda Lawn Mower HRS216K6 PKAA Flywheel Key Replacement: step 6, image 3 of 3
    • Pull to unlatch the cable sheath.
    • Pull the brake cable away from the motor.
  7. Honda Lawn Mower HRS216K6 PKAA Flywheel Key Replacement: step 7, image 1 of 3 Honda Lawn Mower HRS216K6 PKAA Flywheel Key Replacement: step 7, image 2 of 3 Honda Lawn Mower HRS216K6 PKAA Flywheel Key Replacement: step 7, image 3 of 3
    • Push the cable towards the cable anchor to give it enough slack to be removed.
    • Remove the brake cable from the motor.
  8. Honda Lawn Mower HRS216K6 PKAA Flywheel Key Replacement, Disconnect the pull start cord: step 8, image 1 of 3 Honda Lawn Mower HRS216K6 PKAA Flywheel Key Replacement, Disconnect the pull start cord: step 8, image 2 of 3 Honda Lawn Mower HRS216K6 PKAA Flywheel Key Replacement, Disconnect the pull start cord: step 8, image 3 of 3
    • Pull the pull start cord out of the small opening on the handle post and remove it.
  9. Honda Lawn Mower HRS216K6 PKAA Flywheel Key Replacement, Remove the fan cover: step 9, image 1 of 1
    • Remove the three 10 mm nuts securing the fan cover.
  10. Honda Lawn Mower HRS216K6 PKAA Flywheel Key Replacement: step 10, image 1 of 2 Honda Lawn Mower HRS216K6 PKAA Flywheel Key Replacement: step 10, image 2 of 2
    • Remove the fan cover.
    • The fuel tank is connected to the fan cover. They will both come out as one unit.
  11. Honda Lawn Mower HRS216K6 PKAA Flywheel Key Replacement, Remove the cooling fan: step 11, image 1 of 1
    • Remove the 19 mm nut securing the flywheel and cooling fan to the motor.
  12. Honda Lawn Mower HRS216K6 PKAA Flywheel Key Replacement: step 12, image 1 of 2 Honda Lawn Mower HRS216K6 PKAA Flywheel Key Replacement: step 12, image 2 of 2
    • Remove the washer on top of the cooling fan.
    • Remove the cooling fan.
  13. Honda Lawn Mower HRS216K6 PKAA Flywheel Key Replacement, Loosen the flywheel: step 13, image 1 of 2 Honda Lawn Mower HRS216K6 PKAA Flywheel Key Replacement, Loosen the flywheel: step 13, image 2 of 2
    • Caution: The flywheel may come loose at any time during this step, potentially sending itself and the puller into the air. Before you begin this step, be sure to wear PPE.
    • Use a universal puller to loosen the flywheel from the tapered pressure fit on the end of the crankshaft.
    • Attach the universal puller arms underneath the denoted "puller" sections on the flywheel.
    • Use a wrench to torque down the puller to slowly loosen the flywheel.
    • This may take a lot of force.
    • If the flywheel seems to become stuck after significant pressure is applied with the universal puller, use a blowtorch to slowly apply heat where the flywheel contacts the crankshaft.
    • The flywheel will "pop" off the crankshaft once loose.
  14. Honda Lawn Mower HRS216K6 PKAA Flywheel Key Replacement, Remove the flywheel: step 14, image 1 of 3 Honda Lawn Mower HRS216K6 PKAA Flywheel Key Replacement, Remove the flywheel: step 14, image 2 of 3 Honda Lawn Mower HRS216K6 PKAA Flywheel Key Replacement, Remove the flywheel: step 14, image 3 of 3
    • Remove the flywheel.
    • If the flywheel became deformed at all during the last step, it will need to be replaced before reinstallation.
    • During reassembly, make sure to align the flywheel with the flywheel key.
  15. Honda Lawn Mower HRS216K6 PKAA Flywheel Key Replacement, Remove the flywheel key: step 15, image 1 of 2 Honda Lawn Mower HRS216K6 PKAA Flywheel Key Replacement, Remove the flywheel key: step 15, image 2 of 2
    • Use needle nose pliers to remove the flywheel key from its slot in the crankshaft.
    • During reinstallation, make sure the key is fully seated in the slot. Otherwise the flywheel will not fit correctly.
2 other people completed this guide.
Carsten Frauenheim
118,109 Reputation
339 Guides authored
iFixit Member of iFixit
Staff
141 Members
17,911 Guides authored
0 Comments
Past 24 Hours: 1
Past 7 Days: 13
Past 30 Days: 66
All Time: 2,503
