Honda Rear Tine Tiller FRC800K1A Rotary Tine Oil Seals Replacement
  1. Honda Rear Tine Tiller FRC800K1A Rotary Tine Oil Seals Replacement, Disconnect the spark plug wire: step 1, image 1 of 2 Honda Rear Tine Tiller FRC800K1A Rotary Tine Oil Seals Replacement, Disconnect the spark plug wire: step 1, image 2 of 2
    • Before you begin the repair, disconnect the spark plug wire.
    • Firmly grip the base of the connector and pull it away from the spark plug to disconnect it.
  2. Honda Rear Tine Tiller FRC800K1A Rotary Tine Oil Seals Replacement, Turn off the fuel valve: step 2, image 1 of 1
    • Flip the fuel valve switch to the off position.
  3. Honda Rear Tine Tiller FRC800K1A Rotary Tine Oil Seals Replacement, Remove the side tine guards: step 3, image 1 of 2 Honda Rear Tine Tiller FRC800K1A Rotary Tine Oil Seals Replacement, Remove the side tine guards: step 3, image 2 of 2
    • Use a 12 mm socket and wrench to remove the six sets of side guard bolts and nuts, three on each side.
  4. Honda Rear Tine Tiller FRC800K1A Rotary Tine Oil Seals Replacement: step 4, image 1 of 2 Honda Rear Tine Tiller FRC800K1A Rotary Tine Oil Seals Replacement: step 4, image 2 of 2
    • Slide the side guard off of the curved main guard to remove.
    • Repeat the same process on the opposite side.
  5. Honda Rear Tine Tiller FRC800K1A Rotary Tine Oil Seals Replacement, Remove the rotary tine: step 5, image 1 of 1
    • Use a 14 mm socket to remove the two rotary tine retaining bolts.
    • Repeat the same process on the opposite rotary tine.
  6. Honda Rear Tine Tiller FRC800K1A Rotary Tine Oil Seals Replacement: step 6, image 1 of 3 Honda Rear Tine Tiller FRC800K1A Rotary Tine Oil Seals Replacement: step 6, image 2 of 3 Honda Rear Tine Tiller FRC800K1A Rotary Tine Oil Seals Replacement: step 6, image 3 of 3
    • Slide the rotary tine off its axle to remove it.
  7. Honda Rear Tine Tiller FRC800K1A Rotary Tine Oil Seals Replacement, Remove the oil seals: step 7, image 1 of 2 Honda Rear Tine Tiller FRC800K1A Rotary Tine Oil Seals Replacement, Remove the oil seals: step 7, image 2 of 2
    • Wedge a large flathead screwdriver underneath the metal lip on the oil seal.
    • Firmly pry the seal away from the transmission.
  8. Honda Rear Tine Tiller FRC800K1A Rotary Tine Oil Seals Replacement: step 8, image 1 of 2 Honda Rear Tine Tiller FRC800K1A Rotary Tine Oil Seals Replacement: step 8, image 2 of 2
    • With enough room to grab the oil seal, pull it out of its housing.
    • Remove the oil seal.
Refill the transmission with 5.3 quarts of SAE 10W-30 oil.
2 other people completed this guide.
Carsten Frauenheim
118,082 Reputation
339 Guides authored
iFixit Member of iFixit
Staff
141 Members
17,908 Guides authored
0 Comments
Past 24 Hours: 1
Past 7 Days: 2
Past 30 Days: 27
All Time: 1,637
