Honda Rear Tine Tiller FRC800K1A V-Belt Replacement
  1. Honda Rear Tine Tiller FRC800K1A V-Belt Replacement, Disconnect the spark plug wire: step 1, image 1 of 2 Honda Rear Tine Tiller FRC800K1A V-Belt Replacement, Disconnect the spark plug wire: step 1, image 2 of 2
    • Before you begin the repair, disconnect the spark plug wire.
    • Firmly grip the base of the connector and pull it away from the spark plug to disconnect it.
  2. Honda Rear Tine Tiller FRC800K1A V-Belt Replacement, Turn off the fuel valve: step 2, image 1 of 1
    • Flip the fuel valve switch to the off position.
  3. Honda Rear Tine Tiller FRC800K1A V-Belt Replacement, Remove outer belt cover: step 3, image 1 of 1
    • Use a 14 mm socket to remove the bolt securing the outer belt cover.
  4. Honda Rear Tine Tiller FRC800K1A V-Belt Replacement: step 4, image 1 of 3 Honda Rear Tine Tiller FRC800K1A V-Belt Replacement: step 4, image 2 of 3 Honda Rear Tine Tiller FRC800K1A V-Belt Replacement: step 4, image 3 of 3
    • Tilt the outer belt cover down and pull it off of the lip on the inner belt cover to remove it.
  5. Honda Rear Tine Tiller FRC800K1A V-Belt Replacement, Remove the V-belt: step 5, image 1 of 3 Honda Rear Tine Tiller FRC800K1A V-Belt Replacement, Remove the V-belt: step 5, image 2 of 3 Honda Rear Tine Tiller FRC800K1A V-Belt Replacement, Remove the V-belt: step 5, image 3 of 3
    • Push the V-belt towards the transmission pulley to release tension.
    • Slip the V-belt off of the groove in the pulley.
  6. Honda Rear Tine Tiller FRC800K1A V-Belt Replacement: step 6, image 1 of 3 Honda Rear Tine Tiller FRC800K1A V-Belt Replacement: step 6, image 2 of 3 Honda Rear Tine Tiller FRC800K1A V-Belt Replacement: step 6, image 3 of 3
    • Pull the V-belt down and out of the way of the two-prong belt guide.
    • Push the V-belt around and off of the motor pulley to remove.
Carsten Frauenheim
118,082 Reputation
339 Guides authored
iFixit Member of iFixit
Staff
141 Members
17,908 Guides authored
0 Comments
Past 24 Hours: 0
Past 7 Days: 5
Past 30 Days: 42
All Time: 1,535
