Honda Rear Tine Tiller FRC800K1A Wheels Replacement
Prerequisite Only
This guide is only intended to be used as a prerequisite for other guides. It's incomplete by itself.
  1. Honda Rear Tine Tiller FRC800K1A Wheels Replacement, Disconnect the spark plug wire: step 1, image 1 of 2 Honda Rear Tine Tiller FRC800K1A Wheels Replacement, Disconnect the spark plug wire: step 1, image 2 of 2
    • Before you begin the repair, disconnect the spark plug wire.
    • Firmly grip the base of the connector and pull it away from the spark plug to disconnect it.
  2. Honda Rear Tine Tiller FRC800K1A Wheels Replacement, Turn off the fuel valve: step 2, image 1 of 1
    • Flip the fuel valve switch to the off position.
  3. Honda Rear Tine Tiller FRC800K1A Wheels Replacement, Remove the wheels: step 3, image 1 of 3 Honda Rear Tine Tiller FRC800K1A Wheels Replacement, Remove the wheels: step 3, image 2 of 3 Honda Rear Tine Tiller FRC800K1A Wheels Replacement, Remove the wheels: step 3, image 3 of 3
    • Use needle nose pliers to remove the cotter pin from the wheel lock pin.
    • Remove the wheel lock pin.
    • Repeat this same process for the other wheel.
  4. Honda Rear Tine Tiller FRC800K1A Wheels Replacement: step 4, image 1 of 2 Honda Rear Tine Tiller FRC800K1A Wheels Replacement: step 4, image 2 of 2
    • Pull the wheel off of the wheel shaft.
    • Repeat this process for the other wheel.
Carsten Frauenheim
118,082 Reputation
339 Guides authored
iFixit Member of iFixit
Staff
141 Members
17,908 Guides authored
0 Comments
Past 24 Hours: 0
Past 7 Days: 1
Past 30 Days: 2
All Time: 55
