Honeywell HT900C Motor Replacement
  1. Honeywell HT900C Motor Replacement, Motor: step 1, image 1 of 3 Honeywell HT900C Motor Replacement, Motor: step 1, image 2 of 3 Honeywell HT900C Motor Replacement, Motor: step 1, image 3 of 3
    • Remove the six 15 mm screws securing the fan's frame to its outer ring on the back using a Phillips #1 screwdriver.
    • Due to the small size of the screw holes, a long and thin screwdriver may be necessary.
  2. Honeywell HT900C Motor Replacement: step 2, image 1 of 3 Honeywell HT900C Motor Replacement: step 2, image 2 of 3 Honeywell HT900C Motor Replacement: step 2, image 3 of 3
    • To gain access to the fan's inner workings, gently pull the blade cover away from the main body.
  3. Honeywell HT900C Motor Replacement: step 3, image 1 of 2 Honeywell HT900C Motor Replacement: step 3, image 2 of 2
    • Remove the two 36 mm screws from the metal plate located behind the blades using a Phillips #1 screwdriver.
    • The screws can be hard to remove so you may need to twist the screwdriver harder and screws can be removed easily.
  4. Honeywell HT900C Motor Replacement: step 4, image 1 of 3 Honeywell HT900C Motor Replacement: step 4, image 2 of 3 Honeywell HT900C Motor Replacement: step 4, image 3 of 3
    • Carefully pull the motor it out of its resting position and tilt it forward to access the back of the motor.
  5. Honeywell HT900C Motor Replacement: step 5, image 1 of 3 Honeywell HT900C Motor Replacement: step 5, image 2 of 3 Honeywell HT900C Motor Replacement: step 5, image 3 of 3
    • Remove two 10 mm screws from the motor's back using a Phillips #1 screwdriver.
  6. Honeywell HT900C Motor Replacement: step 6, image 1 of 2 Honeywell HT900C Motor Replacement: step 6, image 2 of 2
    • Remove the 20 mm screws beside the fan blade using a Phillips #1 screwdriver.
    • The screws are attached to two parts of the motor so it can easily fall off after removing the screws.
  7. Honeywell HT900C Motor Replacement: step 7, image 1 of 1
    • Carefully remove the circular motor from the square holder.
    • The circular motor is still connected to the fan blades.
  8. Honeywell HT900C Motor Replacement: step 8, image 1 of 2 Honeywell HT900C Motor Replacement: step 8, image 2 of 2
    • Remove the metal washer from the axle.
  9. Honeywell HT900C Motor Replacement: step 9, image 1 of 1
    • Replace the old motor with a new one, and you're done!
    • Using the lubricant to easily put the new motor back.
    • Always double-check that the screws are securely in place.
Duy Anh Nguyen
169 Reputation
1 Guide authored
0 Comments
Past 24 Hours: 3
Past 7 Days: 17
Past 30 Days: 75
All Time: 657
