Honeywell HY-204 Case Replacement
  1. Honeywell HY-204 Case Replacement, Case: step 1, image 1 of 2 Honeywell HY-204 Case Replacement, Case: step 1, image 2 of 2
    • Before you begin, be sure to unplug the fan.
    • Remove the four 14 mm screws from the back of the device using the Phillips #0 Screwdriver.
  2. Honeywell HY-204 Case Replacement: step 2, image 1 of 2 Honeywell HY-204 Case Replacement: step 2, image 2 of 2
    • Pull the front and back parts of the case away from each other until the back is free from the front. This may require a large amount of force.
2 other people completed this guide.
Nolan Ernotte
366 Reputation
3 Guides authored
Cal Poly, Team 10-40, Amido Fall 2014 Member of Cal Poly, Team 10-40, Amido Fall 2014
CPSU-AMIDO-F14S10G40
3 Members
7 Guides authored
0 Comments
Past 24 Hours: 0
Past 7 Days: 0
Past 30 Days: 6
All Time: 2,425
