Honeywell HY-204 Fan Blades Replacement
  1. Honeywell HY-204 Fan Blades Replacement, Case: step 1, image 1 of 2 Honeywell HY-204 Fan Blades Replacement, Case: step 1, image 2 of 2
    • Before you begin, be sure to unplug the fan.
    • Remove the four 14 mm screws from the back of the device using the Phillips #0 Screwdriver.
  2. Honeywell HY-204 Fan Blades Replacement: step 2, image 1 of 2 Honeywell HY-204 Fan Blades Replacement: step 2, image 2 of 2
    • Pull the front and back parts of the case away from each other until the back is free from the front. This may require a large amount of force.
  3. Honeywell HY-204 Fan Blades Replacement, Fan Blades: step 3, image 1 of 2 Honeywell HY-204 Fan Blades Replacement, Fan Blades: step 3, image 2 of 2
    • Remove the hex nut from the fan motor with a 10mm hexagonal ratcheting socket wrench.
    • The nut uses a left-handed thread.
  4. Honeywell HY-204 Fan Blades Replacement: step 4, image 1 of 2 Honeywell HY-204 Fan Blades Replacement: step 4, image 2 of 2
    • Grasp the fan blade firmly and pull upward to remove it from the center column of the fan.
    • The slots on the fan blades and center column need to be aligned for reassembly.
Jenna Johnson
247 Reputation
1 Guide authored
Cal Poly, Team 10-40, Amido Fall 2014 Member of Cal Poly, Team 10-40, Amido Fall 2014
CPSU-AMIDO-F14S10G40
3 Members
7 Guides authored
0 Comments
Past 24 Hours: 0
Past 7 Days: 2
Past 30 Days: 33
All Time: 3,012
