Honeywell HY-204 Fan Motor Replacement
  1. Honeywell HY-204 Fan Motor Replacement, Case: step 1, image 1 of 2 Honeywell HY-204 Fan Motor Replacement, Case: step 1, image 2 of 2
    • Before you begin, be sure to unplug the fan.
    • Remove the four 14 mm screws from the back of the device using the Phillips #0 Screwdriver.
  2. Honeywell HY-204 Fan Motor Replacement: step 2, image 1 of 2 Honeywell HY-204 Fan Motor Replacement: step 2, image 2 of 2
    • Pull the front and back parts of the case away from each other until the back is free from the front. This may require a large amount of force.
  3. Honeywell HY-204 Fan Motor Replacement, Fan Blades: step 3, image 1 of 2 Honeywell HY-204 Fan Motor Replacement, Fan Blades: step 3, image 2 of 2
    • Remove the hex nut from the fan motor with a 10mm hexagonal ratcheting socket wrench.
    • The nut uses a left-handed thread.
  4. Honeywell HY-204 Fan Motor Replacement: step 4, image 1 of 2 Honeywell HY-204 Fan Motor Replacement: step 4, image 2 of 2
    • Grasp the fan blade firmly and pull upward to remove it from the center column of the fan.
    • The slots on the fan blades and center column need to be aligned for reassembly.
  5. Honeywell HY-204 Fan Motor Replacement, Fan Motor: step 5, image 1 of 2 Honeywell HY-204 Fan Motor Replacement, Fan Motor: step 5, image 2 of 2
    • Remove the four 12.7mm screws using the Phillips #0 Screwdriver.
    • Once the screws are removed, lift the motor off its base.
  6. Honeywell HY-204 Fan Motor Replacement: step 6, image 1 of 2 Honeywell HY-204 Fan Motor Replacement: step 6, image 2 of 2
    • Remove the wire connectors from the black, brown, red, blue, white, grey, and green wires. To do this, grip each wire with your hand and use the pliers to de-crimp the heads of each wire connector by applying pressure to the wider ends of the connector until it falls free.
    • While reassembling, apply pressure to the more narrow ends of the wire connectors to re-crimp them onto the wires.
2 other people completed this guide.
Armando Jacob Espinoza
500 Reputation
3 Guides authored
Cal Poly, Team 10-40, Amido Fall 2014 Member of Cal Poly, Team 10-40, Amido Fall 2014
CPSU-AMIDO-F14S10G40
3 Members
7 Guides authored
2 Comments
Where do you purchase the replacement fan motors from?
mattb - Reply
Do you know where I can find the fan motor replacement?
Dave Smith - Reply
Past 24 Hours: 0
Past 7 Days: 5
Past 30 Days: 38
All Time: 6,462
