Hoover LiNX Wheel Replacement
  1. Hoover LiNX Wheel Replacement, Replace The Motor: step 1, image 1 of 1
    • Detach the rolling assembly from the body by pushing the button found at the base.
  2. Hoover LiNX Wheel Replacement: step 2, image 1 of 1
    • Remove the seven 7.5mm Phillips #1 screws from the brush retainer.
  3. Hoover LiNX Wheel Replacement: step 3, image 1 of 2 Hoover LiNX Wheel Replacement: step 3, image 2 of 2
    • Remove the brush and retainer from the rolling assembly.
    • The brush will need to be disconnected from the belt.
  4. Hoover LiNX Wheel Replacement: step 4, image 1 of 1
    • Remove the eight 4mm Phillips #1 screws from the bottom panel.
  5. Hoover LiNX Wheel Replacement: step 5, image 1 of 1
    • Remove the bottom panel.
  6. Hoover LiNX Wheel Replacement: step 6, image 1 of 1
    • Remove the motor.
  7. Hoover LiNX Wheel Replacement, Wheel: step 7, image 1 of 2 Hoover LiNX Wheel Replacement, Wheel: step 7, image 2 of 2
    • Remove the black plastic clamp from inside the wheel axle.
  8. Hoover LiNX Wheel Replacement: step 8, image 1 of 3 Hoover LiNX Wheel Replacement: step 8, image 2 of 3 Hoover LiNX Wheel Replacement: step 8, image 3 of 3
    • Remove broken wheel and replace.
Sara Vlhova
541 Reputation
4 Guides authored
USF Tampa, Team S7-G4, Passmore Spring 2018 Member of USF Tampa, Team S7-G4, Passmore Spring 2018
USFT-PASSMORE-S18S7G4
4 Members
12 Guides authored
One Comment
where can i buy these rubber wheels ? They worn out fast.
The Glider Flyer - Reply
Past 24 Hours: 0
Past 7 Days: 1
Past 30 Days: 10
All Time: 1,659
