Hoover Power Path Pro Advanced Hose Replacement
  1. Hoover Power Path Pro Advanced Hose Replacement, Brush Roller: step 1, image 1 of 2 Hoover Power Path Pro Advanced Hose Replacement, Brush Roller: step 1, image 2 of 2
    • Unplug the vacuum cleaner from the wall outlet before starting. Make sure the water tanks are empty.
    • Lay the cleaner down horizontally with its wheels closest to the floor.
  2. Hoover Power Path Pro Advanced Hose Replacement: step 2, image 1 of 2 Hoover Power Path Pro Advanced Hose Replacement: step 2, image 2 of 2
    • Hold the lower brush roll with both hands and pull outwards until it is detached.
  3. Hoover Power Path Pro Advanced Hose Replacement: step 3, image 1 of 1
    • Unscrew the 6 marked screws using a Phillips #2 head screwdriver.
    • Remove the brush roller.
  4. Hoover Power Path Pro Advanced Hose Replacement, Hose: step 4, image 1 of 1
    • Use a long #2 Philips head screwdriver to remove the 8 numbered screws on the bottom of the cleaner.
    • They will also be indicated on the bottom of the vacuum.
  5. Hoover Power Path Pro Advanced Hose Replacement: step 5, image 1 of 2 Hoover Power Path Pro Advanced Hose Replacement: step 5, image 2 of 2
    • Pull the red handle shown to remove the front suction unit from the cleaner.
  6. Hoover Power Path Pro Advanced Hose Replacement: step 6, image 1 of 1
    • Unscrew the Phillips #2 screw at the bottom of the hose.
  7. Hoover Power Path Pro Advanced Hose Replacement: step 7, image 1 of 1
    • Grab the attachment at tip of the hose and unscrew it. Pull outwards on the hose until completely removed.
3 other people completed this guide.
Cal Poly, Team S16-G5, Banghart Winter 2018 Member of Cal Poly, Team S16-G5, Banghart Winter 2018
CPSU-BANGHART-W18S16G5
5 Members
15 Guides authored
4 Guide Comments
Where can I find this replacement hose?
Jennifer - Reply Share
Complete waste of $$, won’t pick up water unless you apply about 40 lbs of downward force on the %#*@ thing, I tried all the trouble shooting tips, no change, maybe used 3 times. The attachment same thing nada. Basically a toy.
Leigh Robert Smith - Reply Share
Where can I purchase the lower hose?
Eryk H. - Reply Share
I've been trying to find the hose for mine for two years now I even called hoover and they tell me it's unavailable maybe I need to find a Hoover scrap yard lol if anyone knows where I can get one please let me know via email at jefferyalger1959@gmail.com
Jeffery Alger - Reply Share
Past 24 Hours: 0
Past 7 Days: 13
Past 30 Days: 85
All Time: 4,898
