Hoover Power Path Pro Advanced Power Switch Replacement
  1. Hoover Power Path Pro Advanced Power Switch Replacement, Power Switch: step 1, image 1 of 1
    • Remove the lower brushroll from the bottom of the cleaner.
  2. Hoover Power Path Pro Advanced Power Switch Replacement: step 2, image 1 of 1
    • Use a long #2 Philips head to remove the 8 numbered screws on the bottom of the cleaner (They will also be indicated on the bottom of the vacuum).
  3. Hoover Power Path Pro Advanced Power Switch Replacement: step 3, image 1 of 2 Hoover Power Path Pro Advanced Power Switch Replacement: step 3, image 2 of 2
    • Pull the red handle to remove the front suction unit from the cleaner.
  4. Hoover Power Path Pro Advanced Power Switch Replacement: step 4, image 1 of 1
    • Unscrew the hose by using a Phillips #2 to detach it from the top cover of the cleaner.
  5. Hoover Power Path Pro Advanced Power Switch Replacement: step 5, image 1 of 2 Hoover Power Path Pro Advanced Power Switch Replacement: step 5, image 2 of 2
    • Push down on the handle release button. Lift the edge of top cover connected to this button.
    • Repeat the above step for the "On/Off" button.
    • Pull entire top cover off.
    • Caution: when pulling the handle release button, make sure the top of the cleaner does not fall.
  6. Hoover Power Path Pro Advanced Power Switch Replacement: step 6, image 1 of 1
    • Remove the "On/Off" cap by pulling it upwards with caution.
  7. Hoover Power Path Pro Advanced Power Switch Replacement: step 7, image 1 of 1
    • Use a long #2 Philips head to remove the two screws from the arched grey piece.
  8. Hoover Power Path Pro Advanced Power Switch Replacement: step 8, image 1 of 2 Hoover Power Path Pro Advanced Power Switch Replacement: step 8, image 2 of 2
    • Pull out the red power the red power switch.
4 other people completed this guide.
Cal Poly, Team S16-G5, Banghart Winter 2018 Member of Cal Poly, Team S16-G5, Banghart Winter 2018
CPSU-BANGHART-W18S16G5
5 Members
15 Guides authored
3 Guide Comments
What is the part number?
martahayner - Reply
Thanks so much!!
debmccrimm - Reply
you have to test the switch, mine tested ok which led me to the fuse between the motor and switch. It was bad, parts warehouse part # 440004065 does the trick.
frank - Reply
Past 24 Hours: 1
Past 7 Days: 5
Past 30 Days: 24
All Time: 4,033
