Hoover Power Scrub FH50150 Brush Replacement
  1. Hoover Power Scrub FH50150 Brush Replacement, Handle Replacement: step 1, image 1 of 2 Hoover Power Scrub FH50150 Brush Replacement, Handle Replacement: step 1, image 2 of 2
    • Push the button on the top of the clean water/solutions tank and pull on the handle below the button simultaneously. The tank should easily swing out.
  2. Hoover Power Scrub FH50150 Brush Replacement: step 2, image 1 of 2 Hoover Power Scrub FH50150 Brush Replacement: step 2, image 2 of 2
    • Using the screwdriver, unscrew both of the screws on the backside of the handle.
  3. Hoover Power Scrub FH50150 Brush Replacement: step 3, image 1 of 1
    • Pull the handle upwards. It should freely slide away from the base of the machine.
  4. Hoover Power Scrub FH50150 Brush Replacement, Water Tank: step 4, image 1 of 1
    • Unlatch the grey switch labeled “Tank Release”.
  5. Hoover Power Scrub FH50150 Brush Replacement: step 5, image 1 of 1
    • Gently pull on the water tank until it releases from the base.
  6. Hoover Power Scrub FH50150 Brush Replacement, Brush: step 6, image 1 of 2 Hoover Power Scrub FH50150 Brush Replacement, Brush: step 6, image 2 of 2
    • With the vacuum laying on its back pull gently on the brush part and wiggle until it pulls out of place. Now the brushes are ready for cleaning.
Logan Brown
73 Reputation
1 Guide authored
Cal Poly, Team S16-G4, Banghart Winter 2018 Member of Cal Poly, Team S16-G4, Banghart Winter 2018
CPSU-BANGHART-W18S16G4
5 Members
10 Guides authored
0 Comments
Past 24 Hours: 0
Past 7 Days: 4
Past 30 Days: 17
All Time: 2,132
