Hoover T-Series WindTunnel Pet UH30310 Vacuum Belt Replacement
  1. Hoover T-Series WindTunnel Pet UH30310 Vacuum Belt Replacement, Brush: step 1, image 1 of 2 Hoover T-Series WindTunnel Pet UH30310 Vacuum Belt Replacement, Brush: step 1, image 2 of 2
    • Place the vacuum on its back.
    • On the bottom right side, push the red lever to the left.
    • Remove the plastic cover.
  2. Hoover T-Series WindTunnel Pet UH30310 Vacuum Belt Replacement: step 2, image 1 of 3 Hoover T-Series WindTunnel Pet UH30310 Vacuum Belt Replacement: step 2, image 2 of 3 Hoover T-Series WindTunnel Pet UH30310 Vacuum Belt Replacement: step 2, image 3 of 3
    • Grab the red switch under the brush and push left.
    • Then remove the plastic base plate.
  3. Hoover T-Series WindTunnel Pet UH30310 Vacuum Belt Replacement: step 3, image 1 of 3 Hoover T-Series WindTunnel Pet UH30310 Vacuum Belt Replacement: step 3, image 2 of 3 Hoover T-Series WindTunnel Pet UH30310 Vacuum Belt Replacement: step 3, image 3 of 3
    • Use a Phillips #1 screwdriver to remove the two screws on the right side of the brush.
  4. Hoover T-Series WindTunnel Pet UH30310 Vacuum Belt Replacement: step 4, image 1 of 3 Hoover T-Series WindTunnel Pet UH30310 Vacuum Belt Replacement: step 4, image 2 of 3 Hoover T-Series WindTunnel Pet UH30310 Vacuum Belt Replacement: step 4, image 3 of 3
    • Remove the two screws on the left side of the brush.
  5. Hoover T-Series WindTunnel Pet UH30310 Vacuum Belt Replacement: step 5, image 1 of 3 Hoover T-Series WindTunnel Pet UH30310 Vacuum Belt Replacement: step 5, image 2 of 3 Hoover T-Series WindTunnel Pet UH30310 Vacuum Belt Replacement: step 5, image 3 of 3
    • Pull the clear plastic away from the head of the vacuum.
    • Slide the belt off the metal rod with your finger.
    • Pull the brush free.
  6. Hoover T-Series WindTunnel Pet UH30310 Vacuum Belt Replacement, Vacuum Belt: step 6, image 1 of 1
    • Removal of the brush will also remove the belt.
Erik Ingels
193 Reputation
2 Guides authored
Cal Poly, Team S12-G4, Banghart Winter 2018 Member of Cal Poly, Team S12-G4, Banghart Winter 2018
CPSU-BANGHART-W18S12G4
5 Members
9 Guides authored
0 Comments
Past 24 Hours: 1
Past 7 Days: 3
Past 30 Days: 4
All Time: 785
