Hoover WindTunnel 2 Rewind Belt and Roller Brush Replacement
  1. Hoover WindTunnel 2 Rewind Belt and Roller Brush  Replacement, Belt and Roller Brush: step 1, image 1 of 2 Hoover WindTunnel 2 Rewind Belt and Roller Brush  Replacement, Belt and Roller Brush: step 1, image 2 of 2
    • Remove the four 20 mm Phillips #1 head screws holding the top cover on.
    • Lift off the cover.
  2. Hoover WindTunnel 2 Rewind Belt and Roller Brush  Replacement: step 2, image 1 of 1
    • Grab on both ends of the roller brush, lifting it and the attached belt clear of the housing.
  3. Hoover WindTunnel 2 Rewind Belt and Roller Brush  Replacement: step 3, image 1 of 2 Hoover WindTunnel 2 Rewind Belt and Roller Brush  Replacement: step 3, image 2 of 2
    • Reinstall belt and roller making sure that the white text is facing outwards on the belt.
    • Placing the roller brush in its guides will put some tension on the belt after the roller is in place spin it with your hand a couple times to ensure that it spins freely.
2 other people completed this guide.
Thomas Eggenberger
139 Reputation
1 Guide authored
Cal Poly, Team S11-G4, Banghart Winter 2018 Member of Cal Poly, Team S11-G4, Banghart Winter 2018
CPSU-BANGHART-W18S11G4
5 Members
10 Guides authored
One Comment
Thank you, made it easy peasy!
J Colee - Reply
Past 24 Hours: 5
Past 7 Days: 21
Past 30 Days: 111
All Time: 8,885
