Hoover WindTunnel 2 Rewind Dust Cup Assembly Replacement
  1. Hoover WindTunnel 2 Rewind Dust Cup Assembly Replacement, Primary Air Filter: step 1, image 1 of 1
    • Press button on the top of the dust cup and pull back.
    • Remove dust cup from vacuum
  2. Hoover WindTunnel 2 Rewind Dust Cup Assembly Replacement: step 2, image 1 of 1
    • Pull back on black lever and rotate dust cup lid back.
  3. Hoover WindTunnel 2 Rewind Dust Cup Assembly Replacement: step 3, image 1 of 1
    • Lift up on fabric flap to remove filter from vaccum
    • If you wish to clean the filter rather than replace it, it can be washed under a faucet.
    • If washing the filter, make sure it fully dries out before re-installing.
  4. Hoover WindTunnel 2 Rewind Dust Cup Assembly Replacement, Dust Cup Assembly: step 4, image 1 of 1
    • Holding onto both the top handle and dust cup body, twist the two components apart following the instructions printed on the back.
  5. Hoover WindTunnel 2 Rewind Dust Cup Assembly Replacement: step 5, image 1 of 2 Hoover WindTunnel 2 Rewind Dust Cup Assembly Replacement: step 5, image 2 of 2
    • Unscrew the three 4 cm Phillips #3 screws located inside the dust filter compartment to detach the dust filter system.
Chino Cruz
135 Reputation
1 Guide authored
Cal Poly, Team S11-G4, Banghart Winter 2018 Member of Cal Poly, Team S11-G4, Banghart Winter 2018
CPSU-BANGHART-W18S11G4
5 Members
10 Guides authored
0 Comments
Past 24 Hours: 1
Past 7 Days: 5
Past 30 Days: 69
All Time: 4,757
