Hoover WindTunnel 2 Rewind Leaky Hose Replacement
  1. Hoover WindTunnel 2 Rewind Leaky Hose Replacement, Leaky Hose: step 1, image 1 of 1
    • Detach the top of the hose from the device by pressing the release button and pulling up on the hose.
  2. Hoover WindTunnel 2 Rewind Leaky Hose Replacement: step 2, image 1 of 1
    • Remove the other end of the hose by twisting the hose clockwise and pulling it off.
  3. Hoover WindTunnel 2 Rewind Leaky Hose Replacement: step 3, image 1 of 1
    • Firmly insert the larger end of the replacement hose into the upward facing hole in the vacuum.
  4. Hoover WindTunnel 2 Rewind Leaky Hose Replacement: step 4, image 1 of 1
    • Line up the smaller end of the hose and insert it into the downward facing hole.
    • Twist the hose until it locks.
The Hoover Windtunnel 2 Rewind must have a solid and functional hose to work correctly. With this set of instructions, it is easy to replace a leaky hose.
6 other people completed this guide.
Mickey McGuire
253 Reputation
1 Guide authored
Cal Poly, Team S11-G4, Banghart Winter 2018 Member of Cal Poly, Team S11-G4, Banghart Winter 2018
CPSU-BANGHART-W18S11G4
5 Members
10 Guides authored
6 Comments
Good job, helpful. Thanks!
Celeste Williams-Hughes - Reply
Thanks, I'm stuck in quarantine and can't go out to get mine fixed, so I'm so glad I found this. Especially since it was just my hose being filled to the brim with dog hair!
Taylore Kirk - Reply
Same issue. Easy fix thanks!
mark camirand - Reply
That’s great instructions but it’s not even 8 months old. This has happened from day one!!
Linda Schindler - Reply
How long does it take to cool off and turn back on after removing the clog?
Victoria Tingwall - Reply
Past 24 Hours: 8
Past 7 Days: 27
Past 30 Days: 132
All Time: 28,281
