Hoover Windtunnel Air Steerable Upright Motor Assembly Replacement
  1. Hoover Windtunnel Air Steerable Upright Motor Assembly  Replacement, HEPA Filter: step 1, image 1 of 2 Hoover Windtunnel Air Steerable Upright Motor Assembly  Replacement, HEPA Filter: step 1, image 2 of 2
    • Put the cleaner into the upright position, turn the power off, and unplug the power cord.
  2. Hoover Windtunnel Air Steerable Upright Motor Assembly  Replacement: step 2, image 1 of 3 Hoover Windtunnel Air Steerable Upright Motor Assembly  Replacement: step 2, image 2 of 3 Hoover Windtunnel Air Steerable Upright Motor Assembly  Replacement: step 2, image 3 of 3
    • Remove the dirt cup from the cleaner.
    • The HEPA filter is located under the dirt cup and under where it says HEPA.
    • Twist the top counterclockwise to unlock the cap.
  3. Hoover Windtunnel Air Steerable Upright Motor Assembly  Replacement: step 3, image 1 of 2 Hoover Windtunnel Air Steerable Upright Motor Assembly  Replacement: step 3, image 2 of 2
    • Lift the HEPA filter out.
    • Tap the filter against the inside of a trashcan to knock out the dirt and debris or replace as necessary.
    • Do not wash the HEPA Filter.
  4. Hoover Windtunnel Air Steerable Upright Motor Assembly  Replacement, Motor Assembly: step 4, image 1 of 3 Hoover Windtunnel Air Steerable Upright Motor Assembly  Replacement, Motor Assembly: step 4, image 2 of 3 Hoover Windtunnel Air Steerable Upright Motor Assembly  Replacement, Motor Assembly: step 4, image 3 of 3
    • Remove the 4 retaining screws and remove the filter tray.
    • Screw lengths are approximately 3/4".
  5. Hoover Windtunnel Air Steerable Upright Motor Assembly  Replacement: step 5, image 1 of 1
    • Pull the motor housing vertically to dislodge the motor.
  6. Hoover Windtunnel Air Steerable Upright Motor Assembly  Replacement: step 6, image 1 of 3 Hoover Windtunnel Air Steerable Upright Motor Assembly  Replacement: step 6, image 2 of 3 Hoover Windtunnel Air Steerable Upright Motor Assembly  Replacement: step 6, image 3 of 3
    • Use a plastic spudger or opening tool to press on the small circle and wiggle clips free.
2 other people completed this guide.
steven hoover
257 Reputation
2 Guides authored
Cal Poly, Team S7-G2, Banghart Fall 2017 Member of Cal Poly, Team S7-G2, Banghart Fall 2017
CPSU-BANGHART-F17S7G2
5 Members
14 Guides authored
0 Comments
Past 24 Hours: 1
Past 7 Days: 9
Past 30 Days: 46
All Time: 3,952
