Hoover Windtunnel Air Steerable Upright Suction Hose Replacement
  1. Hoover Windtunnel Air Steerable Upright Suction Hose Replacement, Suction Hose: step 1, image 1 of 1
    • Turn the power off and unplug the power cord.
    • Set the cleaner in the upright position.
  2. Hoover Windtunnel Air Steerable Upright Suction Hose Replacement: step 2, image 1 of 1
    • Dislodge hose from plastic clips for ease of removal.
  3. Hoover Windtunnel Air Steerable Upright Suction Hose Replacement: step 3, image 1 of 1
    • Press firmly on the hose button and slide hose out.
  4. Hoover Windtunnel Air Steerable Upright Suction Hose Replacement: step 4, image 1 of 3 Hoover Windtunnel Air Steerable Upright Suction Hose Replacement: step 4, image 2 of 3 Hoover Windtunnel Air Steerable Upright Suction Hose Replacement: step 4, image 3 of 3
    • Pull the hose out of the top of the vacuum.
    • The hose is connected to the vacuum handle.
    • The bottom of the hose should come out when the top of the hose is pulled away from the vacuum.
steven hoover
257 Reputation
2 Guides authored
Cal Poly, Team S7-G2, Banghart Fall 2017 Member of Cal Poly, Team S7-G2, Banghart Fall 2017
CPSU-BANGHART-F17S7G2
5 Members
14 Guides authored
3 Comments
what might my problem be? I will start vacuuming and the noise will change to an almost “air escaping” sound and it loses suction. It will make this sound when the filter is very dirty or when the bag is full.
Currently neither of these two things are applicable but it does it almost immediately after turning on. The sound change seems to be coming from the top of the main unit near the handle.
Mike - Reply
vacuum works hose for cleaning turn on off how to engage hose atachment turn on off
Richard Degrandcourt - Reply
how to turn on hose attachment?
Past 24 Hours: 1
Past 7 Days: 9
Past 30 Days: 47
All Time: 5,446
