Hori Real Arcade Pro N Push Button Replacement
  1. Hori Real Arcade Pro N Push Button Replacement, Push Button: step 1, image 1 of 2 Hori Real Arcade Pro N Push Button Replacement, Push Button: step 1, image 2 of 2
    • Flip your Fight Stick so the bottom is facing up.
    • Remove the sticker covering the screw in the bottom middle of the device.
    • Remove eight screws from the bottom of the device using a Phillips #0 screwdriver.
  2. Hori Real Arcade Pro N Push Button Replacement: step 2, image 1 of 2 Hori Real Arcade Pro N Push Button Replacement: step 2, image 2 of 2
    • Find the storage compartment that holds the USB wire.
    • Open the case by putting your hand in the compartment and pushing up.
    • Put your Fight Stick on its side to make the other steps easier.
  3. Hori Real Arcade Pro N Push Button Replacement: step 3, image 1 of 2 Hori Real Arcade Pro N Push Button Replacement: step 3, image 2 of 2
    • Use your fingers to pull the black grip to detach both wires connected to the pushbutton.
    • Pulling the wire instead of the black grip can cause the wires to not function.
  4. Hori Real Arcade Pro N Push Button Replacement: step 4, image 1 of 2 Hori Real Arcade Pro N Push Button Replacement: step 4, image 2 of 2
    • Twist the button you are planning to remove.
    • The tabs must be on its side as shown in the second picture so it is easier to grab in the next step.
  5. Hori Real Arcade Pro N Push Button Replacement: step 5, image 1 of 3 Hori Real Arcade Pro N Push Button Replacement: step 5, image 2 of 3 Hori Real Arcade Pro N Push Button Replacement: step 5, image 3 of 3
    • Squeeze the tabs in the button.
    • While squeezing, push the button inward, so it falls out.
2 other people completed this guide.
gabriel garcia
175 Reputation
1 Guide authored
0 Guide Comments
Past 24 Hours: 3
Past 7 Days: 16
Past 30 Days: 61
All Time: 2,349
