Hott T725-8G Back Panel Replacement
Prerequisite Only
This is a prerequisite-only guide! This guide is part of another procedure and isn’t meant to be used alone.
  1. Hott T725-8G Back Panel Replacement, Back Panel: step 1, image 1 of 1
    • Remove the back of the device using the Plastic Opening tool by placing it between the front and back panel and gently prying them apart.
  2. Hott T725-8G Back Panel Replacement: step 2, image 1 of 1
    • Once the Plastic Opening tool has separated the halves, use your hands to pull them completely apart.
    • Be careful when doing this - the speaker is attached to the back panel and has wires running to the motherboard in the front panel.
  3. Hott T725-8G Back Panel Replacement: step 3, image 1 of 1
    • Carefully dislodge the speaker from the back panel.
Emma Carroll
220 Reputation
5 Guides authored
UMass Dartmouth, Team 6-2, Martin Fall 2016 Member of UMass Dartmouth, Team 6-2, Martin Fall 2016
UMASSD-MARTIN-F16S6G2
3 Members
11 Guides authored
0 Guide Comments
Past 24 Hours: 1
Past 7 Days: 4
Past 30 Days: 12
All Time: 123
