Hott T725-8G Screen/Display Replacement
  1. Hott T725-8G Screen/Display Replacement, Screen/Display: step 1, image 1 of 1
    • Use the Metal Spudger tool and your fingers to peel off any existing screen protector.
  2. Hott T725-8G Screen/Display Replacement: step 2, image 1 of 1
    • Remove black electrical tape to release the sensor and ribbon wires connecting the camera to the motherboard.
  3. Hott T725-8G Screen/Display Replacement: step 3, image 1 of 1
    • Dislodge the sensor from the front panel.
  4. Hott T725-8G Screen/Display Replacement: step 4, image 1 of 2 Hott T725-8G Screen/Display Replacement: step 4, image 2 of 2
    Tool used on this step:
    Buy
    • Use a pair of Precision Tweezers to squeeze the clip of the ribbon wire to release it.
  5. Hott T725-8G Screen/Display Replacement: step 5, image 1 of 3 Hott T725-8G Screen/Display Replacement: step 5, image 2 of 3 Hott T725-8G Screen/Display Replacement: step 5, image 3 of 3
    • Using a pair of the Precision Tweezers, remove the ribbon wire from the clip.
  6. Hott T725-8G Screen/Display Replacement: step 6, image 1 of 1
    • Follow the guide to remove the motherboard from the back of the display.
  7. Hott T725-8G Screen/Display Replacement: step 7, image 1 of 1
    • Follow the guide to remove the battery from the back of the display.
  8. Hott T725-8G Screen/Display Replacement: step 8, image 1 of 1
    • With the motherboard and battery detached, use the Metal Spudger tool to gently remove the display from the front panel.
  9. Hott T725-8G Screen/Display Replacement: step 9, image 1 of 1
    • Remove Digitizer Panel from the front panel.
  10. Hott T725-8G Screen/Display Replacement: step 10, image 1 of 1
    • Remove the LCD 5-Point Touch Screen from the display case.
  11. Hott T725-8G Screen/Display Replacement: step 11, image 1 of 1
    • Remove the display from the plastic casing. The screen is now ready for replacement.
2 other people completed this guide.
Emma Carroll
193 Reputation
5 Guides authored
UMass Dartmouth, Team 6-2, Martin Fall 2016 Member of UMass Dartmouth, Team 6-2, Martin Fall 2016
UMASSD-MARTIN-F16S6G2
3 Members
11 Guides authored
0 Guide Comments
Past 24 Hours: 0
Past 7 Days: 4
Past 30 Days: 13
All Time: 414
