Hover 1 Eclipse Bluetooth Speaker Replacement
  1. Hover 1 Eclipse Bluetooth Speaker Replacement, Bluetooth Speaker: step 1, image 1 of 3 Hover 1 Eclipse Bluetooth Speaker Replacement, Bluetooth Speaker: step 1, image 2 of 3 Hover 1 Eclipse Bluetooth Speaker Replacement, Bluetooth Speaker: step 1, image 3 of 3
    • Using a Phillips #1 Screwdriver, remove the four 11mm screws that surround the edge of the plug side bottom shell piece.
    • Using a Phillips #1 Screwdriver, remove the four 13mm screws that surround the edge of the plug side bottom shell piece.
    • Remove the plug side bottom shell piece
  2. Hover 1 Eclipse Bluetooth Speaker Replacement: step 2, image 1 of 3 Hover 1 Eclipse Bluetooth Speaker Replacement: step 2, image 2 of 3 Hover 1 Eclipse Bluetooth Speaker Replacement: step 2, image 3 of 3
    • within the plug side shell piece, there are two white and pink wires connecting the shell and the motherboard.
    • On the circuit board by the speaker, carefully squeeze and unplug the small white headers that connect the shell piece to the hoverboard body.
    • On the body of the board, follow the wires that connect the lights to the motherboard. Disconnect these wires from the motherboard by squeezing and pulling the small white headers.
    • Now you can fully remove the shell piece.
  3. Hover 1 Eclipse Bluetooth Speaker Replacement: step 3, image 1 of 3 Hover 1 Eclipse Bluetooth Speaker Replacement: step 3, image 2 of 3 Hover 1 Eclipse Bluetooth Speaker Replacement: step 3, image 3 of 3
    • Using a Phillips #0 Screwdriver, remove the 3 screws holding the speaker to the shell.
    • Lift the speaker out from the casing.
Mina Dedijer
545 Reputation
4 Guides authored
Cal Poly, Team S12-G4, Regan Fall 2019 Member of Cal Poly, Team S12-G4, Regan Fall 2019
CPSU-REGAN-F19S12G4
4 Members
5 Guides authored
0 Comments
Past 24 Hours: 0
Past 7 Days: 1
Past 30 Days: 3
All Time: 345
