Hover-1 Charger Bluetooth Speaker Replacement
  1. Hover-1 Charger Bluetooth Speaker Replacement, Unplugging the Battery: step 1, image 1 of 2 Hover-1 Charger Bluetooth Speaker Replacement, Unplugging the Battery: step 1, image 2 of 2
    • Flip the hoverboard over so that the warning label is facing up.
    • Remove the twelve 12 mm screws with a Phillips #2 screwdriver.
    • Remove the four 10 mm screws with a Phillips #2 screwdriver.
    • The screws nearest to the wheels may be hard to access. Be sure to use a long, thin screwdriver.
  2. Hover-1 Charger Bluetooth Speaker Replacement: step 2, image 1 of 1
    • Pull the right cover away from the hoverboard to expose the battery.
  3. Hover-1 Charger Bluetooth Speaker Replacement: step 3, image 1 of 2 Hover-1 Charger Bluetooth Speaker Replacement: step 3, image 2 of 2
    • Disconnect the two pronged black and yellow cable.
  4. Hover-1 Charger Bluetooth Speaker Replacement: step 4, image 1 of 1
    • Pull the left cover away from the hoverboard.
  5. Hover-1 Charger Bluetooth Speaker Replacement: step 5, image 1 of 2 Hover-1 Charger Bluetooth Speaker Replacement: step 5, image 2 of 2
    • Disconnect the two pronged black and yellow cable. The battery is now fully disconnected.
  6. Hover-1 Charger Bluetooth Speaker Replacement, Bluetooth Speaker: step 6, image 1 of 1
    • Locate the speaker attached to the left cover of the hoverboard.
  7. Hover-1 Charger Bluetooth Speaker Replacement: step 7, image 1 of 2 Hover-1 Charger Bluetooth Speaker Replacement: step 7, image 2 of 2
    • Unplug the red and white four pin connector from the circuit board. Unplugging this connector is photographed as an example.
    • Unplug the white and blue three pin connector from the circuit board.
    • Unplug the white and blue two pin connector from the circuit board.
  8. Hover-1 Charger Bluetooth Speaker Replacement: step 8, image 1 of 2 Hover-1 Charger Bluetooth Speaker Replacement: step 8, image 2 of 2
    • Using a Phillips #1 screwdriver, remove the two 7 mm screws from the circuit board.
  9. Hover-1 Charger Bluetooth Speaker Replacement: step 9, image 1 of 2 Hover-1 Charger Bluetooth Speaker Replacement: step 9, image 2 of 2
    • Using a Phillips #1 screwdriver, remove the three screws securing the speaker to the outer shell.
  10. Hover-1 Charger Bluetooth Speaker Replacement: step 10, image 1 of 1
    • Remove the speaker and circuit board from the outer shell.
Bryson Shishido
145 Reputation
1 Guide authored
Cal Poly, Team S12-G1, Regan Fall 2019 Member of Cal Poly, Team S12-G1, Regan Fall 2019
CPSU-REGAN-F19S12G1
4 Members
6 Guides authored
0 Comments
Past 24 Hours: 1
Past 7 Days: 10
Past 30 Days: 31
All Time: 1,353
