Hover-1 Charger Gyroscope Sensor Board Replacement
  1. Hover-1 Charger Gyroscope Sensor Board Replacement, Unplugging the Battery: step 1, image 1 of 2 Hover-1 Charger Gyroscope Sensor Board Replacement, Unplugging the Battery: step 1, image 2 of 2
    • Flip the hoverboard over so that the warning label is facing up.
    • Remove the twelve 12 mm screws with a Phillips #2 screwdriver.
    • Remove the four 10 mm screws with a Phillips #2 screwdriver.
    • The screws nearest to the wheels may be hard to access. Be sure to use a long, thin screwdriver.
  2. Hover-1 Charger Gyroscope Sensor Board Replacement: step 2, image 1 of 1
    • Pull the right cover away from the hoverboard to expose the battery.
  3. Hover-1 Charger Gyroscope Sensor Board Replacement: step 3, image 1 of 2 Hover-1 Charger Gyroscope Sensor Board Replacement: step 3, image 2 of 2
    • Disconnect the two pronged black and yellow cable.
  4. Hover-1 Charger Gyroscope Sensor Board Replacement: step 4, image 1 of 1
    • Pull the left cover away from the hoverboard.
  5. Hover-1 Charger Gyroscope Sensor Board Replacement: step 5, image 1 of 2 Hover-1 Charger Gyroscope Sensor Board Replacement: step 5, image 2 of 2
    • Disconnect the two pronged black and yellow cable. The battery is now fully disconnected.
  6. Hover-1 Charger Gyroscope Sensor Board Replacement, Gyroscope Sensor Board: step 6, image 1 of 3 Hover-1 Charger Gyroscope Sensor Board Replacement, Gyroscope Sensor Board: step 6, image 2 of 3 Hover-1 Charger Gyroscope Sensor Board Replacement, Gyroscope Sensor Board: step 6, image 3 of 3
    • Unplug the white five pin connector from the gyroscope sensor board.
    • Unplug the red, yellow, blue, green, black and white six pin connector.
    • Unplug the black and red two pin connector.
    • Unplug the black, yellow, green and red four pin connector. Unplugging this connector is photographed as an example.
  7. Hover-1 Charger Gyroscope Sensor Board Replacement: step 7, image 1 of 2 Hover-1 Charger Gyroscope Sensor Board Replacement: step 7, image 2 of 2
    • Remove the four 10 mm screws from the gyroscope sensor board with a Phillips #2 screwdriver.
  8. Hover-1 Charger Gyroscope Sensor Board Replacement: step 8, image 1 of 3 Hover-1 Charger Gyroscope Sensor Board Replacement: step 8, image 2 of 3 Hover-1 Charger Gyroscope Sensor Board Replacement: step 8, image 3 of 3
    • Push the rubber sheaths away from the clasp of the green bullet connector.
    • Grasp the connector at the metal junction and disconnect.
    • Repeat for the yellow and red bullet connectors.
    • There may be a zip tie holding these wires together. Cut this off.
    • These bullet connectors may be hard to disconnect; do not be afraid to pull with strong force.
  9. Hover-1 Charger Gyroscope Sensor Board Replacement: step 9, image 1 of 1
    • Remove the gyroscope sensor board.
Melanie Hardell
505 Reputation
2 Guides authored
Cal Poly, Team S12-G1, Regan Fall 2019 Member of Cal Poly, Team S12-G1, Regan Fall 2019
CPSU-REGAN-F19S12G1
4 Members
6 Guides authored
4 Comments
Hi Where can I find the replacement sensor board? Thanks!
Jason LaDuke - Reply
where do i find the replacement sensor board?
one wheel of my board doesn’t work
Philip Donkoh - Reply
I need one of these replacement gyros please how I get
Matthew Isaiah Cowart - Reply
Worthless guide. No instructions on where to get the replacement gyro boards
Fuckaboi - Reply
Past 24 Hours: 2
Past 7 Days: 14
Past 30 Days: 81
All Time: 4,754
