Hover-1 Charger LED Headlight Replacement
  1. Hover-1 Charger LED Headlight Replacement, Unplugging the Battery: step 1, image 1 of 2 Hover-1 Charger LED Headlight Replacement, Unplugging the Battery: step 1, image 2 of 2
    • Flip the hoverboard over so that the warning label is facing up.
    • Remove the twelve 12 mm screws with a Phillips #2 screwdriver.
    • Remove the four 10 mm screws with a Phillips #2 screwdriver.
    • The screws nearest to the wheels may be hard to access. Be sure to use a long, thin screwdriver.
  2. Hover-1 Charger LED Headlight Replacement: step 2, image 1 of 1
    • Pull the right cover away from the hoverboard to expose the battery.
  3. Hover-1 Charger LED Headlight Replacement: step 3, image 1 of 2 Hover-1 Charger LED Headlight Replacement: step 3, image 2 of 2
    • Disconnect the two pronged black and yellow cable.
  4. Hover-1 Charger LED Headlight Replacement: step 4, image 1 of 1
    • Pull the left cover away from the hoverboard.
  5. Hover-1 Charger LED Headlight Replacement: step 5, image 1 of 2 Hover-1 Charger LED Headlight Replacement: step 5, image 2 of 2
    • Disconnect the two pronged black and yellow cable. The battery is now fully disconnected.
  6. Hover-1 Charger LED Headlight Replacement, LED Headlight: step 6, image 1 of 2 Hover-1 Charger LED Headlight Replacement, LED Headlight: step 6, image 2 of 2
    • Remove the black and red two pin connector from the circuitboard.
  7. Hover-1 Charger LED Headlight Replacement: step 7, image 1 of 2 Hover-1 Charger LED Headlight Replacement: step 7, image 2 of 2
    • Remove the two 12mm screws holding the LED to the front cover with a Phillips #2 screwdriver.
    • Our Hoverboard was missing a screw in the LED housing. Yours may or may not be missing screws as well.
  8. Hover-1 Charger LED Headlight Replacement: step 8, image 1 of 1
    • With the wire unplugged and screws removed, you can now safely seperate the LED from the Hoverboard.
Benji Forest
272 Reputation
2 Guides authored
Cal Poly, Team S12-G1, Regan Fall 2019 Member of Cal Poly, Team S12-G1, Regan Fall 2019
CPSU-REGAN-F19S12G1
4 Members
6 Guides authored
0 Guide Comments
Past 24 Hours: 0
Past 7 Days: 2
Past 30 Days: 12
All Time: 335
