Hover-1 Chrome Outer Shell Replacement
  1. Hover-1 Chrome Outer Shell Replacement, Hover-1 Chrome Disassembly: step 1, image 1 of 1
    • Flip the Hover-1 Chrome upside down.
    • Use a Phillips #2 screwdriver to remove the fourteen 14 mm screws from the bottom of the Hover-1.
    • Break the two black tape circles, and remove the two 15 mm Phillips screws underneath.
  2. Hover-1 Chrome Outer Shell Replacement: step 2, image 1 of 1
    • Lift the shell without the speaker grille and unplug the battery.
  3. Hover-1 Chrome Outer Shell Replacement: step 3, image 1 of 2 Hover-1 Chrome Outer Shell Replacement: step 3, image 2 of 2
    • Lift the shell with the speaker grille.
    • Unplug the speaker.
    • Unplug the LEDs.
    • Unplug the power button
    • Unplug the charging port.
  4. Hover-1 Chrome Outer Shell Replacement, Outer Shell: step 4, image 1 of 1
    • Remove the twelve 14 mm Phillips #2 screws holding the top shell on.
    • The other six screws are on the side without the battery.
  5. Hover-1 Chrome Outer Shell Replacement: step 5, image 1 of 3 Hover-1 Chrome Outer Shell Replacement: step 5, image 2 of 3 Hover-1 Chrome Outer Shell Replacement: step 5, image 3 of 3
    • Free the cables held atop the bracket holding the battery in place.
    • Remove the four 14 mm Phillips #2 screws holding the battery bracket in place.
    • Pull the battery bracket free.
  6. Hover-1 Chrome Outer Shell Replacement: step 6, image 1 of 1
    • Unplug the cords for the top LEDs.
    • The other side of the board is structurally symmetrical. However instead of going under the battery bracket, these cords go through a zip tie. These cables must be removed from the zip tie in order to continue.
  7. Hover-1 Chrome Outer Shell Replacement: step 7, image 1 of 1
    • Turn the board over and pull the top panel off.
Finish Line
Dylan Prins
212 Reputation
1 Guide authored
Cal Poly, Team S4-G1, White Fall 2018 Member of Cal Poly, Team S4-G1, White Fall 2018
CPSU-WHITE-F18S4G1
4 Members
6 Guides authored
1 Guide Comment
Where can i get a replacement shell?
born4roblox - Reply
Past 24 Hours: 1
Past 7 Days: 3
Past 30 Days: 13
All Time: 482
