Hover-1 Coast Board Battery Replacement
  1. Hover-1 Coast Board Battery Replacement, Board Battery: step 1, image 1 of 3 Hover-1 Coast Board Battery Replacement, Board Battery: step 1, image 2 of 3 Hover-1 Coast Board Battery Replacement, Board Battery: step 1, image 3 of 3
    • To remove the battery on the Hover-1 Coast, you must uncover the screws on the top of the board.
    • Using a pick tool, puncture the grip tape and expose the screws.
    • Loosen all four 1" screws using a Phillips #1 screwdriver.
  2. Hover-1 Coast Board Battery Replacement: step 2, image 1 of 3 Hover-1 Coast Board Battery Replacement: step 2, image 2 of 3 Hover-1 Coast Board Battery Replacement: step 2, image 3 of 3
    • Now pull the black protective cover off the board.
    • Locate the battery.
  3. Hover-1 Coast Board Battery Replacement: step 3, image 1 of 3 Hover-1 Coast Board Battery Replacement: step 3, image 2 of 3 Hover-1 Coast Board Battery Replacement: step 3, image 3 of 3
    • The battery is connected by these two sets of wires.
    • Remove the yellow wire first by pulling the two wires gently in opposite directions.
    • Now pull apart the black wire by gently pulling the two wires in opposite directions.
  4. Hover-1 Coast Board Battery Replacement: step 4, image 1 of 3 Hover-1 Coast Board Battery Replacement: step 4, image 2 of 3 Hover-1 Coast Board Battery Replacement: step 4, image 3 of 3
    • Once the battery has been disconnected, gently pry the battery upward.
    • It is important to use a plastic opening tool to avoid puncturing the battery.
    • Once the battery is freed, remove it with your hands.
    • The battery is glued to the case and will require some effort to remove.
One Comment
Where can you order a replacement battery?
Phil - Reply
Past 24 Hours: 0
Past 7 Days: 0
Past 30 Days: 5
All Time: 639
