Hover-1 Eagle Back Wheel Replacement
  1. Hover-1 Eagle Back Wheel Replacement, Back Wheel: step 1, image 1 of 1
    • Peel off the reflective red axle sticker using a plastic spudger.
  2. Hover-1 Eagle Back Wheel Replacement: step 2, image 1 of 1
    • Use a Phillips #2 screwdriver to remove the 2mm screw located underneath the reflective sticker.
  3. Hover-1 Eagle Back Wheel Replacement: step 3, image 1 of 3 Hover-1 Eagle Back Wheel Replacement: step 3, image 2 of 3 Hover-1 Eagle Back Wheel Replacement: step 3, image 3 of 3
    • Grip the deck flare and slide it towards the tail end of the scooter.
  4. Hover-1 Eagle Back Wheel Replacement: step 4, image 1 of 1
    • Remove the 6 mm axle screws by using a hex bit 5.0.
    • Make sure to try loosening both sides. One of the axle screws spins freely and will not loosen.
  5. Hover-1 Eagle Back Wheel Replacement: step 5, image 1 of 3 Hover-1 Eagle Back Wheel Replacement: step 5, image 2 of 3 Hover-1 Eagle Back Wheel Replacement: step 5, image 3 of 3
    • Repeat Steps 1-3 for the other side.
    • Apply pressure to the axle using a hex bit 5.0 to push it slightly out on the other side.
    • Take hold of the 6 mm axle screw on the opposite side and remove the axle by pulling firmly towards you.
  6. Hover-1 Eagle Back Wheel Replacement: step 6, image 1 of 2 Hover-1 Eagle Back Wheel Replacement: step 6, image 2 of 2
    • Pull backwards to remove the back wheel.
    • Washers may fall when the wheel is removed, so make sure to catch or gather the washers.
To reassemble your device, repeat Steps 1-4 in reverse order.
5 other people completed this guide.
Andrew Gaskell
1,137 Reputation
5 Guides authored
Cal Poly, Team S1-G2, White Winter 2020 Member of Cal Poly, Team S1-G2, White Winter 2020
CPSU-WHITE-W20S1G2
4 Members
6 Guides authored
1 Guide Comment
Where do you buy the wheels
Thanks
antonio flores - Reply
Past 24 Hours: 2
Past 7 Days: 15
Past 30 Days: 67
All Time: 3,552
